メインコンテンツにスキップ
How to Clean a GE JCBS250DM2WW Glass Oven Door
必要な工具と部品
  1. How to Clean a GE JCBS250DM2WW Glass Oven Door, How to Clean a GE JCBS250DM2WW Glass Oven Door: 手順 1、 3の画像 1 How to Clean a GE JCBS250DM2WW Glass Oven Door, How to Clean a GE JCBS250DM2WW Glass Oven Door: 手順 1、 3の画像 2 How to Clean a GE JCBS250DM2WW Glass Oven Door, How to Clean a GE JCBS250DM2WW Glass Oven Door: 手順 1、 3の画像 3
    • Disconnect the oven from the power supply.
    • To prevent injuries, ensure that the oven is empty and cool.
  2. How to Clean a GE JCBS250DM2WW Glass Oven Door: 手順 2、 3の画像 1 How to Clean a GE JCBS250DM2WW Glass Oven Door: 手順 2、 3の画像 2 How to Clean a GE JCBS250DM2WW Glass Oven Door: 手順 2、 3の画像 3
    • Open the oven door.
    • Use the the 3/32" Allen wrench to remove the two 8mm x 2mm M2 hex screws.
    • When both screws are removed, the door will separate. Make sure to hold it so it doesn't fall.
  3. How to Clean a GE JCBS250DM2WW Glass Oven Door: 手順 3、 3の画像 1 How to Clean a GE JCBS250DM2WW Glass Oven Door: 手順 3、 3の画像 2 How to Clean a GE JCBS250DM2WW Glass Oven Door: 手順 3、 3の画像 3
    • The first glass panel is located on the bottom part as shown in the image.
    • Dip the soft sponge in the soapy water and gently rub the glass until there is no grease or spots.
    • Use a clean cloth to wipe the glass off so there are no streaks.
  4. How to Clean a GE JCBS250DM2WW Glass Oven Door: 手順 4、 3の画像 1 How to Clean a GE JCBS250DM2WW Glass Oven Door: 手順 4、 3の画像 2 How to Clean a GE JCBS250DM2WW Glass Oven Door: 手順 4、 3の画像 3
    • The second glass panel is located on the top.
    • Use the sponge to clean the glass with a soap solution and soft clean cloth to wipe the glass off.
  5. How to Clean a GE JCBS250DM2WW Glass Oven Door: 手順 5、 3の画像 1 How to Clean a GE JCBS250DM2WW Glass Oven Door: 手順 5、 3の画像 2 How to Clean a GE JCBS250DM2WW Glass Oven Door: 手順 5、 3の画像 3
    • For any hard remaining stains, make a paste of baking powder and water.
    • Mix three table spoons of baking power and two table spoons of water.
    • Use the sponge to apply it on the hard stains and let it rest for two minutes.
    • Use a soft cloth to wipe off the paste from the glass.
  6. How to Clean a GE JCBS250DM2WW Glass Oven Door: 手順 6、 3の画像 1 How to Clean a GE JCBS250DM2WW Glass Oven Door: 手順 6、 3の画像 2 How to Clean a GE JCBS250DM2WW Glass Oven Door: 手順 6、 3の画像 3
    • To reassemble the door, press bottom and top part of the door together.
    • Replace the hex screws using the 3/32" Allen wrench.
  7. How to Clean a GE JCBS250DM2WW Glass Oven Door: 手順 7、 1の画像 1
    • The oven door glass is now clean.
    • Be careful when reconnecting the oven to power.
終わりに
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Flying Feather
メンバー登録日: 09/17/23
145 ポイント
1ガイドが承認済み
チーム
York University, Team 19-19, O'Regan Fall 2023 York University, Team 19-19, O'Regan Fall 2023人のメンバー
YORK-O'REGAN-F23S19G19
1 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 8
過去 30 日: 21
今までの合計 227
