メインコンテンツにスキップ
How to Clean a Dirt Devil Vacuum Cleaner Roller Brush
必要な工具と部品
  1. How to Clean a Dirt Devil Vacuum Cleaner Roller Brush, How to Clean a Dirt Devil Vacuum Cleaner Roller Brush: 手順 1、 1の画像 1
    • Lay the vacuum cleaner on the floor so that the bottom of the vacuum is facing upwards.
  2. How to Clean a Dirt Devil Vacuum Cleaner Roller Brush: 手順 2、 1の画像 1
    • Use a Phillips head screwdriver to remove eight screws.
  3. How to Clean a Dirt Devil Vacuum Cleaner Roller Brush: 手順 3、 1の画像 1
    • Disassemble the vacuum head and pop out your roller brush.
  4. How to Clean a Dirt Devil Vacuum Cleaner Roller Brush: 手順 4、 1の画像 1
    • Cut the ends with scissors.
    • Cover the floor with papers to prevent debris and hair from falling on the ground.
  5. How to Clean a Dirt Devil Vacuum Cleaner Roller Brush: 手順 5、 1の画像 1
    • Use a brush to clean the roller brush.
  6. How to Clean a Dirt Devil Vacuum Cleaner Roller Brush: 手順 6、 2の画像 1 How to Clean a Dirt Devil Vacuum Cleaner Roller Brush: 手順 6、 2の画像 2
    • Put the rectangular part on both sides.
  7. How to Clean a Dirt Devil Vacuum Cleaner Roller Brush: 手順 7、 2の画像 1 How to Clean a Dirt Devil Vacuum Cleaner Roller Brush: 手順 7、 2の画像 2
    • Check if the belt is attached.
    • Check if the motor part is well inserted with the belt attached to the roller brush.
    • Make sure the shape of the motor fits to prevent it from falling.
  8. How to Clean a Dirt Devil Vacuum Cleaner Roller Brush: 手順 8、 1の画像 1
    • Use your Phillips head screwdriver to screw in all eight of the screws.
ゴール
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Minji Choi
メンバー登録日: 02/21/21
184 ポイント
1ガイドが承認済み
チーム
University of North Texas, Team S1-G8, Raign Spring 2021 University of North Texas, Team S1-G8, Raign Spring 2021人のメンバー
UNT-RAIGN-S21S1G8
2 メンバー
1のガイドは作成済み
4 件のコメント
Might be helpful if you showed where all 8 screws are seeing how I can only find 6 and cannot get it open!
Crystal - 返信
in the front there are to wheels, pop them out and you will see the other 2 screws
Mario Lore -
my power express lite only has 6 screws as well. I cannot get it open, I'm afraid it will break if I keep prying.
Gregory Penniston - 返信
Can I hand wash the brushes and rollers.
Lynne - 返信
コメントを追加
統計データ:
過去 24時間: 6
過去 7 日: 52
過去 30 日: 235
今までの合計 8,169
