メインコンテンツにスキップ
How to Clean a Clouded Glass Oven Door
必要な工具と部品
  1. How to Clean a Clouded Glass Oven Door, How to Clean a Clouded Glass Oven Door: 手順 1、 3の画像 1 How to Clean a Clouded Glass Oven Door, How to Clean a Clouded Glass Oven Door: 手順 1、 3の画像 2 How to Clean a Clouded Glass Oven Door, How to Clean a Clouded Glass Oven Door: 手順 1、 3の画像 3
    • Open the oven door until it lays flat.
  2. How to Clean a Clouded Glass Oven Door: 手順 2、 3の画像 1 How to Clean a Clouded Glass Oven Door: 手順 2、 3の画像 2 How to Clean a Clouded Glass Oven Door: 手順 2、 3の画像 3
    • Add a tablespoon of baking soda to a medium size bowl.
    • Pour 1 cup of vinegar into the bowl.
    • Mix the solution together.
  3. How to Clean a Clouded Glass Oven Door: 手順 3、 3の画像 1 How to Clean a Clouded Glass Oven Door: 手順 3、 3の画像 2 How to Clean a Clouded Glass Oven Door: 手順 3、 3の画像 3
    • Pour the mix on the open oven glass door, making sure to cover the entire area.
    • Leave it for about 45 minutes
    • You might notice the mixture bubbling and rising. Wait until it simmers down but continues to bubble.
  4. How to Clean a Clouded Glass Oven Door: 手順 4、 3の画像 1 How to Clean a Clouded Glass Oven Door: 手順 4、 3の画像 2 How to Clean a Clouded Glass Oven Door: 手順 4、 3の画像 3
    • 30 minutes - 1 hour later, use a stainless steel sponge to scrub the glass door. The mix aids in loosening deep stains.
    • Keep scrubbing until the surface feels clean and the stains are gone.
    • If your arm is getting tried from the intense scrubbing, take a break!
  5. How to Clean a Clouded Glass Oven Door: 手順 5、 3の画像 1 How to Clean a Clouded Glass Oven Door: 手順 5、 3の画像 2 How to Clean a Clouded Glass Oven Door: 手順 5、 3の画像 3
    • Once the stains are gone, use a towel to clean off the residue and remaining mixture.
    • Rinse the residue off the towel and repeat until the door is entirely clean of dirt and mixture residue.
  6. How to Clean a Clouded Glass Oven Door: 手順 6、 3の画像 1 How to Clean a Clouded Glass Oven Door: 手順 6、 3の画像 2 How to Clean a Clouded Glass Oven Door: 手順 6、 3の画像 3
    • Add soap and water to a sponge and gently clean the oven door.
    • Use a damp towel to wipe off the soap, then use a paper towel to thoroughly dry the oven glass door, ensuring there is no leftover water.
終わりに
Enjoy you clean glass oven door!
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Zion-Faith Akakpo
メンバー登録日: 01/08/24
133 ポイント
1ガイドが承認済み
チーム
York University, Team 2-1, O'Regan Winter 2024 York University, Team 2-1, O'Regan Winter 2024人のメンバー
YORK-O'REGAN-W24S2G1
1 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 40
今までの合計 113
