はじめに
In this guide, I am going to show you how to clean up solder pads on a logic board. I'll be working on a Chinese A13 Allwinner tablet. I'm cleaning the solder pads for the battery, so I can solder a new battery onto the logic board.
必要な工具と部品
この手順で使用する道具:FixHub Smart Soldering Iron$79.95
Place the de-soldering wick on the solder joint and put the tip of the soldering iron on it so the wick can heat up and absorb the old solder.
Lift the wick and the soldering iron up from the logic board at the same time. Failure to do so can cause the leftover solder to harden and solder the wick to the logic board and you could easily pull a logic board pad off.
For more soldering guides and tips, check out this page.
96 の人々がこのガイドを完成させました。
