メインコンテンツにスキップ
How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller
必要な工具と部品
  1. How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller, How to Clean the L2 and R2 Buttons: 手順 1、 2の画像 1 How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller, How to Clean the L2 and R2 Buttons: 手順 1、 2の画像 2
    • Use a Phillips #00 screwdriver to remove the four 6.0 mm screws located on the back of the controller.
  2. How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller: 手順 2、 3の画像 1 How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller: 手順 2、 3の画像 2 How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller: 手順 2、 3の画像 3
    • Separate the front and the back of the controller by pulling both pieces apart at the same time.
    • Be very careful and gentle when pulling the shells apart because the blue ribbon can become detached and damaged.
  3. How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller: 手順 3、 2の画像 1 How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller: 手順 3、 2の画像 2
    • Carefully unplug the blue ribbon from the body of the controller shell.
  4. How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller: 手順 4、 3の画像 1 How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller: 手順 4、 3の画像 2 How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller: 手順 4、 3の画像 3
    • Remove the left and right triggers by wiggling the buttons sideways until they are completely off.
  5. How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller: 手順 5、 2の画像 1 How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller: 手順 5、 2の画像 2
    • Take the Q-tip and soak it into the isopropyl alcohol.
    • Clean around the trigger button area as well as under and above the rubber padding.
  6. How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller: 手順 6、 3の画像 1 How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller: 手順 6、 3の画像 2 How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller: 手順 6、 3の画像 3
    • Put the L2 and R2 buttons back into place by simply forcing them into position until properly locked.
  7. How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller: 手順 7、 2の画像 1 How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller: 手順 7、 2の画像 2
    • Attach the blue ribbon back into its original location so that the two shells of the controller are connected.
  8. How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller: 手順 8、 2の画像 1 How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller: 手順 8、 2の画像 2
    • Put the two shells of the controller together by pushing them together at the same time.
  9. How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller: 手順 9、 3の画像 1 How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller: 手順 9、 3の画像 2 How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller: 手順 9、 3の画像 3
    • Screw the four 6.0mm screws on the back of the controller using the Phillips #00 screwdriver.
ゴール
作成者
1人の作成者と共同作成されました。
Joseph Cao
メンバー登録日: 09/14/23
169 ポイント
1ガイドが承認済み
チーム
York University, Team 2-5, O'Regan Fall 2023 York University, Team 2-5, O'Regan Fall 2023人のメンバー
YORK-O'REGAN-F23S2G5
1 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 16
過去 7 日: 134
過去 30 日: 330
今までの合計 1,518
