メインコンテンツにスキップ
How to Clean Split Air Conditioner
必要な工具と部品
  1. How to Clean Split Air Conditioner, How to Clean Split Air Conditioner: 手順 1、 1の画像 1
    • The very first thing one has to do while leaning an air conditioner is to turn the unit off and then to unplug it.
  2. How to Clean Split Air Conditioner, Blow Air without Targeting the Air Reflectors: 手順 2、 1の画像 1
    • Blow air to the air conditioner with air blower but make sure that the air pressure does not get to the air reflectors of the unit.
  3. How to Clean Split Air Conditioner, Use Cool Water: 手順 3、 1の画像 1
    • Hot water is hazardous for the closely bound metallic plates as they may get expanded due to it. It is advised to use cool water while washing an air conditioner.
  4. How to Clean Split Air Conditioner, Place the Unit into a Drainable Place: 手順 4、 1の画像 1
    • Garages, porches and courtyards are good places to clean or wash split air conditioners as they mostly have arrangements for water drainage.
  5. How to Clean Split Air Conditioner, Cover the Wires with Water Proof Material: 手順 5、 1の画像 1
    • It is always better to cover the electric wires of air conditioner with water proofing material. If not done so, then there is a chance for the wires to get wet and this can lead to damage or short circuiting.
ゴール
5 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
markirwin
メンバー登録日: 08/20/16
245 ポイント
1ガイドが承認済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 12
過去 30 日: 48
今までの合計 6,636
