メインコンテンツにスキップ
How to Clean Nintendo Entertainment System Cartridges
必要な工具と部品
  1. How to Clean Nintendo Entertainment System Cartridges, Take Apart the Cartridge: 手順 1、 1の画像 1
    • Remove the three screws on the bottom of the cartridge. While most of the time the screws are security screws, sometimes there are Phillips/Flathead screws.
  2. How to Clean Nintendo Entertainment System Cartridges, Mix the Abrasive Paste: 手順 2、 2の画像 1 How to Clean Nintendo Entertainment System Cartridges, Mix the Abrasive Paste: 手順 2、 2の画像 2
    • Simply put about 2 tablespoons of baking soda on the cartridge contacts. Then put enough water on the baking soda until it is the consistency of a thick paste.
  3. How to Clean Nintendo Entertainment System Cartridges, Scrub the Contacts: 手順 3、 1の画像 1
    • Take something like a toothbrush or the scraping part of a sponge and scrub the cartridge contacts.
    • After scrubbing for about 4-5 minutes, rinse the cartridge board off in the sink. Let it dry for about 4 hours after pouring alcohol under the chips.
終わりに
And with that your cartridge should be working properly!
3 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
[deleted]
メンバー登録日: 06/12/22
569 ポイント
2のガイドは作成済み
4件のガイドコメント
Is this a joke?
Mizuho Chan - 返信
Why would it be a joke? Because it's a simple procedure that everybody should know? Or do you have a better way?
Randall Mattoon -
In my opinion, a less abrasive metal polish would probably be better to start with.
Jeff Griffith - 返信
Whatever happened to the tried and true method of blowing on the cartridge? It worked as a kid (back when we didn’t know that our breath had water vapor and we were actually destroying our cartridges)!
mwbarnhart - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 28
過去 30 日: 99
今までの合計 4,986
