メインコンテンツにスキップ
How to Change an Indoor Doorknob Handle
必要な工具と部品
  1. How to Change an Indoor Doorknob Handle, How to Change an Indoor Doorknob Handle: 手順 1、 1の画像 1
    • Parts: (in order from left to right)
    • Short Screws
    • Latch mechanism with latch face
    • Long screws
    • Door knob with peg and screw holes (inside of the room)
    • Door knob with screw holes (outside of the room)
  2. How to Change an Indoor Doorknob Handle: 手順 2、 1の画像 1
    • Face the inside of the knob, you should see two Phillips head screws on either side of the central knob.
  3. How to Change an Indoor Doorknob Handle: 手順 3、 1の画像 1
    • Unscrew both long screws.
  4. How to Change an Indoor Doorknob Handle: 手順 4、 1の画像 1
    • Remove the door knob on both sides of the door.
  5. How to Change an Indoor Doorknob Handle: 手順 5、 1の画像 1
    • You will see the latch face plate (the rectangular piece of metal) where the latch of the door knob is located.
  6. How to Change an Indoor Doorknob Handle: 手順 6、 1の画像 1
    • Unscrew the two short screws on the latch face plate.
  7. How to Change an Indoor Doorknob Handle: 手順 7、 1の画像 1
    • Remove the latch face plate and latch mechanism.
  8. How to Change an Indoor Doorknob Handle: 手順 8、 1の画像 1
    • Push the new latch mechanism with latch face plate into the door.
    • The slanted side of the latch mechanism will be facing the direction that the door closes.
  9. How to Change an Indoor Doorknob Handle: 手順 9、 1の画像 1
    • Screw in both short screws of the latch face plate.
  10. How to Change an Indoor Doorknob Handle: 手順 10、 1の画像 1
    • Insert the door knob that goes on the inside of the room, aligning the peg and screw holes with the threaded cylinders of the latch mechanism.
  11. How to Change an Indoor Doorknob Handle: 手順 11、 1の画像 1
    • Align the door knob that goes on the outside of the room, aligning the peg and screw holes with the threaded cylinders of the latch mechanism.
  12. How to Change an Indoor Doorknob Handle: 手順 12、 1の画像 1
    • Screw in both long screws on both sides of the door knob.
  13. How to Change an Indoor Doorknob Handle: 手順 13、 1の画像 1
    • Turn the door knob to test your work.
終わりに
To put the old door knob back on or to change to a different door knob repeat steps from the beginning.
6 の人々がこのガイドを完成させました。
作成者
7人の作成者と共同で作成されました。
Mallory
メンバー登録日: 02/19/15
220 ポイント
1ガイドが承認済み
チーム
CSU Stanislaus, Team 1-1, Moberly Spring 2015 CSU Stanislaus, Team 1-1, Moberly Spring 2015人のメンバー
CSUS-MOBERLY-S15S1G1
4 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 10
過去 30 日: 48
今までの合計 9,268
