はじめに
Follow this guide to calibrate the in-screen optical fingerprint sensor in your Motorola phone. You should perform the calibration whenever you replace the screen to ensure that the fingerprint sensor is accurate and secure.
You'll need the fingerprint sensor calibration toolkit in order to complete this procedure.
必要な工具と部品
Open the phone app.
Open the dial screen.
Enter *#*#2486#*#* on the dial pad.
With the indented side facing down, place the pink box over the red box on the bottom of the screen.
With the indented side facing down, place the black box over the red box on the bottom of the screen.
With the grooved side down and the grooves vertical, place the pink box over the red box on the bottom of the screen.
Your optical fingerprint sensor is calibrated and ready for use.
If the calibration fails for any reason, repeat the calibration procedure.
ある他の人がこのガイドを完成しました。
