はじめに
Since B & W did not respond to my repair request, I decided to open the device myself to repair it.
For me it was just a blown fuse.
(original description in German)
Da B&W nicht auf meine Reparaturanfrage reagierte, habe ich mich entschlossen, dass Gerät selber zu öffnen bzw zu reparieren.
Bei mir war es nur eine defekte Sicherung.
必要な工具と部品
Put the unit on its side and then remove the rubber plate from the bottom.
then unscrew the four screws (tamper-resistant Torx, but a small screwdriver is enough here).
Carefully remove the ribbon (press the clamp still in front) and lay the docking arm to one side.
Use a flat plastic tool or a blunt knife in the slot between the chrome bar and speaker cover to push the grille outward, while at the same time pressing the plastic fastener on the back side at the edge. USE CAUTION, the clips can break easily. Then slide the cover slowly to the side.
Remove the 8 philips screws from the front of the unit.
The remove the 2 smaller philips screws from the rear of the unit behind the tweeters.
It is not necessary to remove the two small Philips screws (behind the tweeters) to split the until in half.
I was unable to halve the unit without removing them.
Note: the split line is between the chrome back shell and the front black plastic. Tge pictures provided on the site don't show where/how the two halves are split. (Do not try to split the unit by halving the black front plastic section) .
Carefully pull the housing towards you to split the unit apart.
Loosen and remove the 3 cables (shown with the RED arrows in the picture)
Remove the screws from the power supply (4 pieces shown with the GREEN arrows) and remove the power supply.
Remove the screws holding the heat-conducting sheet (5 pieces shown with the YELLOW arrow).
solder the new 250V T1.6A fuse to the board
und wo bitte, ist die Abbildung der Sicherung?
Gude! Hast du mal eine Lösung für die Modernisierung vom 30pin gefunden? (Adapter, Bluetooth o.ä.)
partysahne - 返信
Ich suche auch einen passenden AirPlay Adapter auf 30Pin. Ich habe einen gekauft, um jetzt festzustellen, dass es für diesen keine App mehr gibt.
Der Layen i-dock Bluetooth Receiver als 30 Pi Aufsteckmodul funktioniert bei Android und bei Ihrer Phone
Having checked the fuse and the capacitors, I found on my two power supplies (I bought a second broken one for spare parts) that this resistor had blown or at least was without a jacket.
As such I couldn't determine the value, and as it is buried so deep in the board, I stopped the repair here.
Der defekte Widerstand hat 0,33 Ohm (orange, orange, silber, gold).
Laut untenstehendem Post von zeprep gibt das erwähnte Forum unter #97 die Farben rot rot silber gold mit dem Wert 0,22 Ohm und 0,5 Watt an. Er schreibt, dass dann fast sicher noch mehr defekt ist.
VauWeh -
17 の人々がこのガイドを完成させました。
24 件のコメント
Mein Zeppelin schaltet sich nicht ein (die LED bleibt aus).
Also dachte ich auch, dass die Sicherung oder etwas anderes am Netzteil defekt ist. Ich habe den Zeppelin wie in dieser sehr hilfreichen Anleitung geöffnet, aber die Sicherung ist ok.
Wenn ich mit dem Multimeter die Spannung am Netzteil Ausgang messe ist diese aber 0V (zwischen allen Pins).
Bedeutet das, dass das Netzteil kaputt ist?
Falls ja, an welcher Komponente liegt das am ehesten?
Mein Sohnemann (1.5-jährig) hat auf der Rückseite des Zeppelins einen Schlüssel in den Lautsprecher hineingesteckt, den ich nun nicht mehr raus bekomme. Kann ich zu dem Schlüssel gelangen, wenn ich das Ding gemäss dieser Anleitung aufschraube oder ist es aussichtslos?
Der Zeppelin funktioniert immer noch einwandfrei.
hallo simone,
da der Schlüssel am Lautsprecher magnetisch klebt, wist du ihn nur rausbekommen, wenn du das teil gemäß Anleitung aufschraubst !
Hast super geklappt nach der Anleitung! Nur gibt es auf der Platine drei Sicherungen. Die Porzellansicherung lässt sich einfach aus den Hütchen ziehen... genau hinsehen. Die anderen beiden sehen aus wie kleine orange Kästchen und sitzen genau auf der anderen Seite der Platine links und recht. Die sind glaube ich hitzeempfindlich und gehen bei 85°C dahin... Diese lassen sich nur auslöten wenn das Hitzeleitblech abgeschraubt ist.
Mis zeppelin dejaron de sonar y ahora cuando lo prendo suena un golpe seco y deja de sonar pero si prende normal solo no suena y es el ruido fuerte del principio, que pudiese ser?
Super Anleitung!
Bei mir ist auch die Sicherung durchgebrannt und habe nun eine neue eingebaut und siehe da, der zeppelin schaltet sich wieder an!
Leider bekomme ich nun absolut keinen Sound mehr aus den Lautsprechern:( Hat irgendwer eine Idee woran dies liegen könnte? Habe alle Stecker wieder angesteckt und auch alle Input Varianten ausprobiert.
Ich habe leider urplötzlich ein Hintergrundrauschen. Scheint vom
Netzteil zu kommen laut einem „Experten“ von B&W. Hatte das schon einmal jemand und wenn ja welches Bauteil des Netzteils könnte hier die Ursache sein? Besten Dank!
Hi Tobias,
hatte ich bei mir auch. Bei mir war es ein Kondensator ( 16V 2200uF) am Netzteil das geplatzt ist. Habe ich durch einen stärkeren (35V 2200uF) ersetzt.
Hallo zusammen,
Ich habe einen Zeppelin der älteren Generation also ohne AirPlay.
Leider ist mein AUX Eingang “ausgenudelt" der Stecker greift einfach nicht mehr. Ich würde den gerne wechseln wen möglich.
Hat jemand eine Idee ob und wie das möglich ist.
Mit freundlichen Grüßen
F
Toll repariert.
mein Zeppelin erster Generation.
zeigt plötzlich im ON Zustand nur noch das Blaue Licht für den iPhone Kanal.
kann allerdings nicht mehr auf Aux den Grünen Kanal umschalten.
Kennt jemand eine Lösung ?!
fritzlang1 - 返信
I successfully changed the capacitors in the power supply but after a year or so the unit is on the blink (literally!) again. I just bought the capacitors from the nearest electronics shop and I think, from looking around comments that I can find on the web, it is probably advisable to go for high quality capacitors (electrolytic capacitors are very sensitive to reverse voltages or excess voltage spikes). A tube of thermal paste cost more than the capacitors, which gives a clue to their quality! I don’t read German but Google translate does a good enough job in this case.
Habe ebenfalls einen Zeppelin der 1. Generation von einem Bekannten bekommen, der versucht hat, die Sicherung auszutauschen. Hat nicht funktioniert und die Sicherung ist zerbrochen. Habe mir neue besorgt, kann sie aber nicht auf die Kappen aufstecken obwohl sie die richtige Größe haben, hat jemand da eine Idee?
Der Halter für einen iPod hat ein Flachbandkabel, ist ja auch in der Anleitung beschrieben. Im Gerät selber befindet sich aber noch ein zweites Flachbandkabel, wo wird das angeschlossen?
Linnks oben neben Subwoofer https://appsolute.hu/2013/01/bowers-wilk...
Hallo allerseits,
wir hatten am Sonntag in der gesamten Gegend für mehrere Stunden Stromausfall als der Zeppelin an war und nach dem Stromausfall bekommen wir unseren Zeppelin Air nicht mehr an. Es tut sich nichts, auch mit einem gleichen Netzkabel. Kann das an der Sicherung im Gerät liegen?
Vielleicht gab's eine kurze Überspannung. Dafür ist die Sicherung da. Ein Austausch ist ein guter Tipp!
VauWeh -
HAllo allerseits.
Hier steht ein Zeppelin erster Generation, bei diesem Leuchtet die LED konstant Blau.
Ein Kanalwechsel ist nicht möglich, Audio Signal kommt auch keines durch.
lässt sich das Reparieren?
hello
i’m looking for thedocking arm switch belt of bowers & wilkins zeppelin speaker.
can i get from you?
Hi all….
you will find everything you dig for on the following forum : https://www.abcelectronique.com/forum/sh...
a lot of posts are in english… but schematics are universal
Hi, habe ein Zeppelin geschenkt bekommen auf dem der Stoff an der eine Spitze gerissen ist. Kann sowas repariert werden oder einfach so lassen? Habe Angst, dass es immer mehr aufreisst.
