はじめに
Use this guide to replace the battery stretch release adhesive in your Kobo Libra Colour eReader.
Regardless if your battery came with stretch release adhesive or normal adhesive, you should replace it with stretch release adhesive for easier future disassembly.
必要な工具と部品
If you're reusing your battery, use blunt nose tweezers, or your fingers, to remove any remaining adhesive on the bottom of the battery.
Use your hands to grip the black pull tab and the blue liner on the new stretch release adhesive strip.
Peel the adhesive strip off its clear liner to expose the adhesive underneath.
Place the strip on the bottom of the battery, making sure the black pull tab sticks out slightly from the edge of the battery with the cable.
While holding the battery over its spot in the frame, temporarily reconnect the battery cable to ensure the battery gets aligned properly.
Place the battery into its spot in the frame and press down to adhere it.
If you have more internal reassembly remaining (like reconnecting other cables) disconnect the battery. Otherwise, you can keep the battery connected.
Return to the original guide and continue reassembly, skipping steps you did for this procedure.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
