メインコンテンツにスキップ
How to Alter a Large Dress to Fit
必要な工具と部品
  1. How to Alter a Large Dress to Fit, How to Alter a Large Dress to Fit: 手順 1、 1の画像 1
    • Put on your dress.
    • Pinching the waistline, grab your ruler and measure from your hip.
    • This number will tell you how much you need to take in to make your dress fit.
  2. How to Alter a Large Dress to Fit: 手順 2、 1の画像 1
    • Turn your dress inside out and lay it on a smooth surface.
    • Using your measurements from Step 1, measure out evenly from the seam line how much you need to take in on each side.
    • As you measure how much you take in, use the clothespins as a marker.
  3. How to Alter a Large Dress to Fit: 手順 4、 1の画像 1
    • Carefully put on your dress to make sure that it fits you in the right way.
    • Now that your dress fits how you would like, carefully take it off and lay it back on a flat surface.
    • Using chalk or a pen, make a line that connects all the pins.
    • This line will be a guide for when you use the sewing machine.
  4. How to Alter a Large Dress to Fit: 手順 6、 1の画像 1
    • Thread your sewing machine.
    • If you need help on how to thread the sewing machine, here is a guide on how to.
    • Carefully push your dress through and begin sewing your new seam.
  5. How to Alter a Large Dress to Fit: 手順 7、 1の画像 1
    • When you're done sewing your dress, flip it so that it is right side out and put it on.
    • If there is any excess fabric, you can cut it away, leaving 1/4 of an inch of the leftover fabric by the seam.
終わりに
This is an easy and low budget way to fix a dress that is too large. Check the tag on the dress to see how you should care for it after. It is best recommended that you let your dress air dry.
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Viviane Dobis
メンバー登録日: 10/21/20
145 ポイント
1ガイドが承認済み
チーム
Texas Tech, Team S14-G7, Cowan Fall 2020 Texas Tech, Team S14-G7, Cowan Fall 2020人のメンバー
TTU-COWAN-F20S14G7
2 メンバー
1のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 18
今までの合計 1,299
