メインコンテンツにスキップ
How to Adjust the Truss Rod on an Acoustic Guitar
必要な工具と部品
  1. How to Adjust the Truss Rod on an Acoustic Guitar, How to Adjust the Truss Rod on an Acoustic Guitar: 手順 1、 3の画像 1 How to Adjust the Truss Rod on an Acoustic Guitar, How to Adjust the Truss Rod on an Acoustic Guitar: 手順 1、 3の画像 2 How to Adjust the Truss Rod on an Acoustic Guitar, How to Adjust the Truss Rod on an Acoustic Guitar: 手順 1、 3の画像 3
    • Unwind and remove the strings
    • Turn the tuning pegs to release tension in the strings, and then pull the strings away, detaching them from the headstock
  2. How to Adjust the Truss Rod on an Acoustic Guitar: 手順 2、 3の画像 1 How to Adjust the Truss Rod on an Acoustic Guitar: 手順 2、 3の画像 2 How to Adjust the Truss Rod on an Acoustic Guitar: 手順 2、 3の画像 3
    • Remove the truss rod cover with the necessary tool (depending on your guitar).
    • A Phillips 0 screwdriver is used here to unscrew the 2 x 1/4" Small Phillips guitar screws from the truss rod cover.
    • There are three screws holding the truss rod cover in place.
  3. How to Adjust the Truss Rod on an Acoustic Guitar: 手順 3、 2の画像 1 How to Adjust the Truss Rod on an Acoustic Guitar: 手順 3、 2の画像 2
    • Use the Allen Wrench to adjust the truss rod according to the warp of the neck.
    • For a forward or “U-shaped” bow, turn the truss rod counterclockwise. For a backward bow adjustment, adjust the truss rod clockwise.
    • A “U-shaped” bow is too tight; it has extra space toward the center of the neck, and bows outward and toward the strings. A backward bow is too loose; it arches inward and away from the strings.
  4. How to Adjust the Truss Rod on an Acoustic Guitar: 手順 4、 3の画像 1 How to Adjust the Truss Rod on an Acoustic Guitar: 手順 4、 3の画像 2 How to Adjust the Truss Rod on an Acoustic Guitar: 手順 4、 3の画像 3
    • Re-string the guitar by reattatching them to the headstock.
    • Turn the tuning pegs to bring the strings back to tension.
    • At the same time, adjust the bridge evenly with the neck ( if it is not already glued into the saddle) by moving it with your hand.
  5. How to Adjust the Truss Rod on an Acoustic Guitar: 手順 5、 1の画像 1
    • Using your eyes or a metal ruler, check the distance from the strings to the frets on the neck.
    • You can use a metal ruler to measure out approximately 2.5 mm for an acoustic guitar, depending on your preference.
  6. How to Adjust the Truss Rod on an Acoustic Guitar: 手順 6、 1の画像 1
    • Using the Allen Wrench, make any final adjustments to the truss while the strings are at tension.
    • You may use a tuner to help adjust the strings to the desired tension
  7. How to Adjust the Truss Rod on an Acoustic Guitar: 手順 7、 2の画像 1 How to Adjust the Truss Rod on an Acoustic Guitar: 手順 7、 2の画像 2
    • Replace the truss rod cover.
    • Re-tune the guitar.
終わりに
Reattach the truss rod cover to the headstock of your guitar using the 2 x 1/4 “ Phillips screws and Phillips 0 screwdriver.
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Taryn Wilson
メンバー登録日: 10/07/19
172 ポイント
1ガイドが承認済み
チーム
Eastern Washington University, Team S27-G20, Munoz Fall 2019 Eastern Washington University, Team S27-G20, Munoz Fall 2019人のメンバー
EWU-MUNOZ-F19S27G20
1 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 11
過去 30 日: 50
今までの合計 2,030
