メインコンテンツにスキップ
How to Adjust the Truss Rod of a 2011 Epiphone Les Paul Special II
必要な工具と部品
  1. How to Adjust the Truss Rod of a 2011 Epiphone Les Paul Special II, How to Adjust the Truss Rod of a 2011 Epiphone Les Paul Special II: 手順 1、 2の画像 1 How to Adjust the Truss Rod of a 2011 Epiphone Les Paul Special II, How to Adjust the Truss Rod of a 2011 Epiphone Les Paul Special II: 手順 1、 2の画像 2
    • Remove the three 12.7 mm screws from the truss rod cap on the head-stock with a Phillips #0 screwdriver.
    • Start with the bottom two screws. This will allow you to use the the third as a pivot to help with getting the cap out from under the strings.
  2. How to Adjust the Truss Rod of a 2011 Epiphone Les Paul Special II: 手順 2、 1の画像 1
    • Loosen the strings by turning the tuning pegs. The direction will vary depending on the side of the peg.
    • Detuning helps to avoid injury by reducing the risk of a string snapping.
    • You don't need to detune the strings all the way. You just should go until you can easily bend the string above the nut.
  3. How to Adjust the Truss Rod of a 2011 Epiphone Les Paul Special II: 手順 3、 2の画像 1 How to Adjust the Truss Rod of a 2011 Epiphone Les Paul Special II: 手順 3、 2の画像 2
    • Insert the hex key into the truss rod bolt where the neck meets the head-stock and adjust the truss rod tension as needed.
    • Tightening towards the D-string (clockwise) helps to bend the center of the neck toward the string and loosening towards the G-string (counterclockwise) lets the strings pull the head-stock downwards.
    • Be sure to make small adjustments, as overtightening the truss rod can lead to the neck of your guitar snapping under load!
  4. How to Adjust the Truss Rod of a 2011 Epiphone Les Paul Special II: 手順 4、 1の画像 1
    • Tune the guitar to bring the tension from the strings back to what they would see during normal play.
    • You will likely have to retune all the strings.
    • Test the guitar by playing a little bit to check that have a comfortable amount of string bend and have eliminated all fret buzz.
  5. How to Adjust the Truss Rod of a 2011 Epiphone Les Paul Special II: 手順 5、 2の画像 1 How to Adjust the Truss Rod of a 2011 Epiphone Les Paul Special II: 手順 5、 2の画像 2
    • Reinstall the truss rod cap, starting with the top screw.
  6. How to Adjust the Truss Rod of a 2011 Epiphone Les Paul Special II: 手順 6、 1の画像 1
    • After letting the guitar rest overnight, check to see if the neck is mostly straight.
    • You will want to have a small amount of relief to avoid buzzing.
終わりに
While playing the guitar is very much possible after adjusting the truss rod, it can easily change during a longer practice session. Playing on an over tightened truss rod can potentially damage the neck, so be sure that the adjustments you made were sound before playing excessively.
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Noah Eaton
メンバー登録日: 10/04/20
151 ポイント
1ガイドが承認済み
チーム
University of North Texas, Team S2-G11, Raign Fall 2020 University of North Texas, Team S2-G11, Raign Fall 2020人のメンバー
UNT-RAIGN-F20S2G11
1 メンバー
1のガイドは作成済み
2 件のコメント
In the intro you talk about tightening the truss rod to relieve fret buzz. Tightening the truss rod will produce more back-bow and result in more fret buzz. Also, how can you have looser strings and still have the same "tuning"? Strings need a certain tension for a certain length to produce the pitch you are after.
Tom Whitworth - 返信
Notes on Fret 18 & 19 on high E sound the same.(Just on high E, ever other notes sounds good). Help 🙏
Tosin Jerry - 返信
コメントを追加
統計データ:
過去 24時間: 9
過去 7 日: 68
過去 30 日: 242
今までの合計 11,795
