メインコンテンツにスキップ
How to Adjust the Action and Intonation of a Guitar
必要な工具と部品
  1. How to Adjust the Action and Intonation of a Guitar, How to Adjust the Action and Intonation of a Guitar: 手順 1、 1の画像 1
    • Locate the truss rod, found either on the headstock, under a plate in the headstock, or on the body towards the base of the neck.
  2. How to Adjust the Action and Intonation of a Guitar: 手順 2、 3の画像 1 How to Adjust the Action and Intonation of a Guitar: 手順 2、 3の画像 2 How to Adjust the Action and Intonation of a Guitar: 手順 2、 3の画像 3
    • As you adjust the truss rod, listen for fret buzz or dead spots. These usually create a sound that rings out less than it should. Keep adjusting until the guitar reaches its best tone.
    • For humped necks, loosen the truss rod by turning the Allen wrench counterclockwise. For bowed necks, tighten the truss rod by turning the Allen wrench clockwise.
    • Use an Allen wrench that can adjust the truss rod.
    • TAKE THIS STEP SLOWLY. To make small adjustments, turn the allen wrench a quarter of a turn at a time, checking the neck regularly.
  3. How to Adjust the Action and Intonation of a Guitar: 手順 3、 3の画像 1 How to Adjust the Action and Intonation of a Guitar: 手順 3、 3の画像 2 How to Adjust the Action and Intonation of a Guitar: 手順 3、 3の画像 3
    • On the bridge, locate the saddles by finding the spot strings rest on. Raise the action of the saddles by turning the Allen wrench clockwise. Lower the action of the saddles by turning the Allen wrench counterclockwise.
    • The height of the action is up to player preference. Listen continuously while adjusting.
  4. How to Adjust the Action and Intonation of a Guitar: 手順 4、 3の画像 1 How to Adjust the Action and Intonation of a Guitar: 手順 4、 3の画像 2 How to Adjust the Action and Intonation of a Guitar: 手順 4、 3の画像 3
    • Repeat this process for all strings, adjusting the sides of each saddle evenly so the string won't rest unevenly.
  5. How to Adjust the Action and Intonation of a Guitar: 手順 5、 2の画像 1 How to Adjust the Action and Intonation of a Guitar: 手順 5、 2の画像 2
    • Play a few notes between each adjustment to prevent fret buzz and dead spots.
  6. How to Adjust the Action and Intonation of a Guitar: 手順 6、 2の画像 1 How to Adjust the Action and Intonation of a Guitar: 手順 6、 2の画像 2
    • Check guitar intonation by listening to the twelfth fret notes and the twelfth fret harmonic of each string.
    • With a screwdriver, turn the screws below the saddles clockwise if the fretted note sounds higher pitched than the harmonic; turn them counterclockwise if the fretted notes is lower pitched than the harmonic.
  7. How to Adjust the Action and Intonation of a Guitar: 手順 7、 3の画像 1 How to Adjust the Action and Intonation of a Guitar: 手順 7、 3の画像 2 How to Adjust the Action and Intonation of a Guitar: 手順 7、 3の画像 3
    • Repeat for all six strings.
終わりに
Now enjoy your guitar!
作成者
4人の作成者と共同で作成されました。
Kenneth Studman
メンバー登録日: 03/24/21
154 ポイント
1ガイドが承認済み
チーム
UMass Dartmouth, Team S2-G15, Riel Spring 2021 UMass Dartmouth, Team S2-G15, Riel Spring 2021人のメンバー
UMASSD-RIEL-S21S2G15
1 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 89
過去 30 日: 566
今までの合計 10,095
