メインコンテンツにスキップ
How to Adjust a Piano Key Slip
必要な工具と部品
  1. How to Adjust a Piano Key Slip, How to Adjust a Piano Key Slip: 手順 1、 3の画像 1 How to Adjust a Piano Key Slip, How to Adjust a Piano Key Slip: 手順 1、 3の画像 2 How to Adjust a Piano Key Slip, How to Adjust a Piano Key Slip: 手順 1、 3の画像 3
    • Locate the keys that hold your key slip to the piano.
    • They are typically underneath the piano keyboard and there will be between two and four screws.
    • Check to see what kind of screw it is. In the case of this piano, it is a flathead screw; however there could be a variety of screws.
  2. How to Adjust a Piano Key Slip: 手順 2、 3の画像 1 How to Adjust a Piano Key Slip: 手順 2、 3の画像 2 How to Adjust a Piano Key Slip: 手順 2、 3の画像 3
    • Remove all the screws from the piano and set them aside.
  3. How to Adjust a Piano Key Slip: 手順 3、 2の画像 1 How to Adjust a Piano Key Slip: 手順 3、 2の画像 2
    • Gently remove your key slip using your hands.
    • The key slip is the piece of wood that sits in front of the keys.
  4. How to Adjust a Piano Key Slip: 手順 4、 3の画像 1 How to Adjust a Piano Key Slip: 手順 4、 3の画像 2 How to Adjust a Piano Key Slip: 手順 4、 3の画像 3
    • Check for debris under the keys.
    • You can vacuum out dust or remove pieces of paper and other objects that have fallen behind the key slip or through the keys.
  5. How to Adjust a Piano Key Slip: 手順 5、 3の画像 1 How to Adjust a Piano Key Slip: 手順 5、 3の画像 2 How to Adjust a Piano Key Slip: 手順 5、 3の画像 3
    • Replace your key slip, ensuring that it sits evenly between the two ends of the piano.
  6. How to Adjust a Piano Key Slip: 手順 6、 3の画像 1 How to Adjust a Piano Key Slip: 手順 6、 3の画像 2 How to Adjust a Piano Key Slip: 手順 6、 3の画像 3
    • Re-screw the key slip onto the piano.
    • Don't tighten the screws all the way down at first. Screw each one in a little bit to make it doesn't become uneven.
    • Go back and tighten the screws to your desired tightness.
    • Check the keys to make sure that the they are no longer sticking, and that the key slip is not too tight.
  7. How to Adjust a Piano Key Slip: 手順 7、 3の画像 1 How to Adjust a Piano Key Slip: 手順 7、 3の画像 2 How to Adjust a Piano Key Slip: 手順 7、 3の画像 3
    • Check each key to make sure they are no longer sticking.
    • If you were successful, no keys will stick and your key slip will be properly placed!
終わりに
Congratulations! Your keys are no longer sticky and if your key slip slips out of place again you now know how to fix it!
2 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Chloe Nielsen
メンバー登録日: 11/17/21
184 ポイント
1ガイドが承認済み
チーム
Idaho State University, Team 1-1, Watkins Fall 2021 Idaho State University, Team 1-1, Watkins Fall 2021人のメンバー
ISU-WATKINS-F21S1G1
1 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 18
過去 30 日: 78
今までの合計 1,155
