メインコンテンツにスキップ
How to Adjust Cantilever Bicycle Brakes
必要な工具と部品
  1. How to Adjust Cantilever Bicycle Brakes, How to Adjust Cantilever Bicycle Brakes: 手順 1、 3の画像 1 How to Adjust Cantilever Bicycle Brakes, How to Adjust Cantilever Bicycle Brakes: 手順 1、 3の画像 2 How to Adjust Cantilever Bicycle Brakes, How to Adjust Cantilever Bicycle Brakes: 手順 1、 3の画像 3
    • Lift bicycle onto the rear wheel by holding the handlebars.
    • Roll the rear wheel forward while placing the handlebars on the ground so that the bike rests upside down.
  2. How to Adjust Cantilever Bicycle Brakes: 手順 2、 2の画像 1 How to Adjust Cantilever Bicycle Brakes: 手順 2、 2の画像 2
    • Identify the brake that is rubbing against the bike rim by spinning each wheel while listening for contact.
    • Identify which brake pad is making contact (left or right).
  3. How to Adjust Cantilever Bicycle Brakes: 手順 3、 3の画像 1 How to Adjust Cantilever Bicycle Brakes: 手順 3、 3の画像 2 How to Adjust Cantilever Bicycle Brakes: 手順 3、 3の画像 3
    • Loosen the 6mm hex screw that is holding the noisy brake to the frame.
    • Make sure not to remove the bolt completely.
  4. How to Adjust Cantilever Bicycle Brakes: 手順 4、 1の画像 1
    • Shift the brake so that the pad no longer makes contact with the rim.
  5. How to Adjust Cantilever Bicycle Brakes: 手順 5、 2の画像 1 How to Adjust Cantilever Bicycle Brakes: 手順 5、 2の画像 2
    • Rotate the bicycle tire to ensure the brake is no longer rubbing against the rim.
    • Keep your fingers free of the spokes while the wheel is spinning!
  6. How to Adjust Cantilever Bicycle Brakes: 手順 6、 2の画像 1 How to Adjust Cantilever Bicycle Brakes: 手順 6、 2の画像 2
    • Hold the brake in the new position where it no longer rubs.
    • Use the 6 mm hex key to tighten the brake bolt back on.
  7. How to Adjust Cantilever Bicycle Brakes: 手順 7、 2の画像 1 How to Adjust Cantilever Bicycle Brakes: 手順 7、 2の画像 2
    • Rotate the wheel again to ensure the brake did not change positions while you were tightening it.
  8. How to Adjust Cantilever Bicycle Brakes: 手順 8、 1の画像 1
    • Flip the bike back onto its wheels.
終わりに
Go ride your bike!
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Devaughantee
メンバー登録日: 09/30/20
194 ポイント
1ガイドが承認済み
チーム
York University, Team S4-G21, Woodhouse Fall 2020 York University, Team S4-G21, Woodhouse Fall 2020人のメンバー
YORK-WOODHOUSE-F20S4G21
2 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 5
過去 30 日: 14
今までの合計 954
