メインコンテンツにスキップ
How to Adjust Black and Decker TR1278B Browning Dial
必要な工具と部品
  1. How to Adjust Black and Decker TR1278B Browning Dial, Top Cover: 手順 1、 1の画像 1
    • Unplug the toaster before disassembly.
    • Remove the carriage lever by pulling it away from the toaster.
  2. How to Adjust Black and Decker TR1278B Browning Dial: 手順 2、 1の画像 1
    • Toaster will be turned upside down. Clear crumb tray or work over a paper towel.
    • Turn the toaster upside down.
    • Unscrew all four 4mm screws on the bottom using a Phillip's head #2 (PH2) screwdriver.
    • Or a slightly different model has six screws that require an allen wrench (hex key). Ones that have a ball end will not work. I had to use one that had more of a Star of David, pointy pattern to it.
  3. How to Adjust Black and Decker TR1278B Browning Dial: 手順 3、 1の画像 1
    • Detach the bottom from the front cover using the plastic opening tool.
  4. How to Adjust Black and Decker TR1278B Browning Dial: 手順 4、 1の画像 1
    • Turn the toaster right side up.
    • Support the bottom. The ribbon cable that connects the toaster to the front cover can be damaged.
    • Lift the front cover.
    • Lift carefully. Again the ribbon cable can be damaged.
  5. How to Adjust Black and Decker TR1278B Browning Dial: 手順 5、 1の画像 1
    • Detach the bundled cable connector from the toaster by carefully pulling it away from the circuit board.
  6. How to Adjust Black and Decker TR1278B Browning Dial, How to Adjust Black and Decker TR1278B Browning Dial: 手順 6、 2の画像 1 How to Adjust Black and Decker TR1278B Browning Dial, How to Adjust Black and Decker TR1278B Browning Dial: 手順 6、 2の画像 2
    • Remove the front cover.
  7. How to Adjust Black and Decker TR1278B Browning Dial: 手順 7、 2の画像 1 How to Adjust Black and Decker TR1278B Browning Dial: 手順 7、 2の画像 2
    • Unscrew the circuit behind the browning dial on the front cover.
    • Do not lose the washers on the screws.
  8. How to Adjust Black and Decker TR1278B Browning Dial: 手順 8、 1の画像 1
    • Remove the circuit.
    • The dial and buttons on the front cover will be loose.
  9. How to Adjust Black and Decker TR1278B Browning Dial: 手順 9、 1の画像 1
    • Turn the knob on the circuit board left or right to adjust the browning dial.
終わりに
作成者
3人の作成者と共同で作成されました。
Dominic Gamonez
メンバー登録日: 02/15/17
233 ポイント
2のガイドは作成済み
チーム
USF Tampa, Team 8-1, Eyestone Spring 2017 USF Tampa, Team 8-1, Eyestone Spring 2017人のメンバー
USFT-EYESTONE-S17S8G1
3 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 11
今までの合計 692
