メインコンテンツにスキップ
How to Add a Hole in a Leather Belt
必要な工具と部品
  1. How to Add a Hole in a Leather Belt, How to Add a Hole in a Leather Belt: 手順 1、 1の画像 1
    • Make sure the leather belt is clean by wiping it down with water and drying it before working on it beforehand to get rid of any excess dirt or grime.
  2. How to Add a Hole in a Leather Belt: 手順 2、 1の画像 1
    • Find a flat and durable surface to work on, preferably a wooden work table. If that’s not available, then use a good sized wooden block to work on.
  3. How to Add a Hole in a Leather Belt: 手順 3、 1の画像 1
    • Using a measuring tape, measure the distance between each of the existing holes to figure out the distance to place your new hole.
  4. How to Add a Hole in a Leather Belt: 手順 4、 1の画像 1
    • Mark where you want the hole with either a pen or indent using the pin punch. Mark as many as you see fit before continuing onto the next step.
  5. How to Add a Hole in a Leather Belt: 手順 5、 1の画像 1
    • Align the pin punch where you marked the hole.
    • Make sure to tighten the grip on the pin before hammering onto the marked area. Continue this for all the other hole marks.
  6. How to Add a Hole in a Leather Belt: 手順 6、 1の画像 1
    • Push the pin all the way through the hole to make sure the hole is fully formed.
  7. How to Add a Hole in a Leather Belt: 手順 7、 1の画像 1
    • Clean off any stray leather bits left from the hole placement using a razor blade.
終わりに
Once you complete all your steps, make sure to congratulate yourself on your new belt! Now you can hold up anything you need without any issues.
作成者
1人の作成者と共同作成されました。
Feliza Castillo
メンバー登録日: 05/24/23
195 ポイント
1ガイドが承認済み
チーム
York University, Team A-2, Allen Summer 2023 York University, Team A-2, Allen Summer 2023人のメンバー
YORK-ALLEN-SU23SAG2
1 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 32
今までの合計 228
