メインコンテンツにスキップ
How to Add Privacy to a Wood Fence
必要な工具と部品
  1. How to Add Privacy to a Wood Fence, How to Add Privacy to a Wood Fence: 手順 1、 1の画像 1
    • After buying my home, I realized that anybody could walk by my back fence and look right into my backyard. I'm sure I'm not the only one who feels a little uneasy about such a lack of privacy.
  2. How to Add Privacy to a Wood Fence: 手順 2、 1の画像 1
    • To add privacy and provide stability to an older fence, I headed to my local hardware store and bought a few fence boards. The boards pictured cost $3.85 a board and, depending on how tall you need your boards cut, one fence board provides approximately three privacy boards.
  3. How to Add Privacy to a Wood Fence: 手順 3、 2の画像 1 How to Add Privacy to a Wood Fence: 手順 3、 2の画像 2
    • Once I purchased my boards, it was time to cut them. I used a miter saw, but a hand saw works just fine. In order to find the length of your privacy boards, measure from the top rail of your existing fence to the future height that you would like to extend your fence.
  4. How to Add Privacy to a Wood Fence: 手順 4、 2の画像 1 How to Add Privacy to a Wood Fence: 手順 4、 2の画像 2
    • Once you have your measurement, mark your board (measure twice, cut once) and then make your cut.
  5. How to Add Privacy to a Wood Fence: 手順 5、 3の画像 1 How to Add Privacy to a Wood Fence: 手順 5、 3の画像 2 How to Add Privacy to a Wood Fence: 手順 5、 3の画像 3
    • After you mark the board in order to notch it, move your miter saw to a 45 degree angle to make the first cut.
    • Then flip the board and shift the saw to make the second cut.
  6. How to Add Privacy to a Wood Fence: 手順 6、 1の画像 1
    • You should now have a board that is ready to be installed (I suggest doing as many as you need and then installing them rather than doing one at a time).
  7. How to Add Privacy to a Wood Fence: 手順 7、 2の画像 1 How to Add Privacy to a Wood Fence: 手順 7、 2の画像 2
    • Using a drill and screws (any screws will work, but for aesthetics, I suggest deck screws). I use a four-screw pattern simply for looks and stability, but it is up to you how you would like to attach your new privacy boards.
  8. How to Add Privacy to a Wood Fence: 手順 8、 1の画像 1
    • Voila! Your backyard has transformed into a personal/private oasis. Congratulations! Enjoy your newfound security and privacy (plus it was cheap).
終わりに
This is a fun and easy weekend project, so if you have little ones around that you are trying to teach creativity or woodworking to, have them help out. Remember, safety should be your #1 priority. Enjoy.
4 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Brett
メンバー登録日: 02/19/15
236 ポイント
1ガイドが承認済み
チーム
CSU Stanislaus, Team 1-2, Moberly Winter 2015 CSU Stanislaus, Team 1-2, Moberly Winter 2015人のメンバー
CSUS-MOBERLY-W15S1G2
4 メンバー
1のガイドは作成済み
1件のガイドコメント
Great idea, for added privacy & security.
Jose - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 36
今までの合計 7,370
