メインコンテンツにスキップ
How to Activate 12 V Aux Power in a 2007-2014 Chevrolet Suburban
必要な工具と部品
  1. How to Activate 12 V Aux Power in a 2007-2014 Chevrolet Suburban, How to Activate 12 V Aux Power in a 2007-2014 Chevrolet Suburban: 手順 1、 1の画像 1
    • Locate the wiring harness bundle, which exits the firewall underneath the brake booster.
  2. How to Activate 12 V Aux Power in a 2007-2014 Chevrolet Suburban: 手順 2、 1の画像 1
    • Identify the auxiliary wire, which is folded and taped to either the wiring harness or the fire wall.
  3. How to Activate 12 V Aux Power in a 2007-2014 Chevrolet Suburban: 手順 3、 1の画像 1
    • Use a knife to cut the tape away from the wire and unravel it.
  4. How to Activate 12 V Aux Power in a 2007-2014 Chevrolet Suburban: 手順 4、 1の画像 1
    • Run the wire against the battery box.
  5. How to Activate 12 V Aux Power in a 2007-2014 Chevrolet Suburban: 手順 5、 3の画像 1 How to Activate 12 V Aux Power in a 2007-2014 Chevrolet Suburban: 手順 5、 3の画像 2 How to Activate 12 V Aux Power in a 2007-2014 Chevrolet Suburban: 手順 5、 3の画像 3
    • Place the ring terminal (washer end) of the wire on the right post located at the front of the battery.
    • Place the 10 mm washer on the post.
    • Tighten the washer using a 10 mm wrench, crescent wrench, or pliers.
    • Post size and location may vary slightly in different models. The washer will fit snuggly around the correct post.
  6. How to Activate 12 V Aux Power in a 2007-2014 Chevrolet Suburban: 手順 6、 1の画像 1
    • After hooking up the wire, check to make sure the 40 amp fuse is installed for the auxiliary pin.
    • If the fuse is not installed, there will be an empty space. This fuse can be purchased at any automotive shop.
ゴール
13 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Lauryn Johnson
メンバー登録日: 01/19/16
454 ポイント
1ガイドが承認済み
チーム
Oakland University, Team 6-14, Walwema Winter 2016 Oakland University, Team 6-14, Walwema Winter 2016人のメンバー
OAK-WALWEMA-W16S6G14
1 メンバー
1のガイドは作成済み
6 件のコメント
This sends constant power to the trailer. What if I wanted to make that power switched by the ignition so when the key is off I can be confident that the trailer won't kill my truck battery? I know I can just unplug the trailer harness or pull this fuse to stop it, but That might be easy to forget to do.
Eric Wonderlich Jr. - 返信
Eric, did you ever get an answer to your inquiry about killing the power to the trailer when the key is in the off position?
Bobby Burke -
It’s not a break booster, it is a brake booster. If you are going to be an author, you should know the meaning of the words you use.
Albert - 返信
Never fails some troll somewhere..
Garry Foster -
“Words have meaning” geez Cyber Warrior. Tough talk from a distance. ?
nshourds -
コメントを追加
統計データ:
過去 24時間: 6
過去 7 日: 29
過去 30 日: 167
今までの合計 34,021
