メインコンテンツにスキップ
How to Fix A Loose Bicycle Chain
必要な工具と部品
  1. How to  Fix A Loose Bicycle Chain, How to  Fix A Loose Bicycle Chain: 手順 1、 2の画像 1 How to  Fix A Loose Bicycle Chain, How to  Fix A Loose Bicycle Chain: 手順 1、 2の画像 2
    • Determine if your chain is loose. As shown in the pictures, the bike chain is hanging low; this is an excellent indication that your bike chain is loose.
    • Your bike might have oil all over its chain and gear, so it's best to wear gloves.
  2. How to  Fix A Loose Bicycle Chain: 手順 2、 1の画像 1
    • Use a bike stand or wall to help keep your bike from falling.
  3. How to  Fix A Loose Bicycle Chain: 手順 3、 2の画像 1 How to  Fix A Loose Bicycle Chain: 手順 3、 2の画像 2
    • Loosen both nuts on either side of the rear wheel using a socket wrench, rotating the wrench from left to right.
    • Be sure to not fully unscrew the nut or else the rear wheel will no longer be connected to the bike and you will have to spend time reassembling it.
  4. How to  Fix A Loose Bicycle Chain: 手順 4、 2の画像 1 How to  Fix A Loose Bicycle Chain: 手順 4、 2の画像 2
    • Hold the end of the bike wheel with one hand and the bike's frame with your other hand.
    • Pull the wheel back from the frame.
    • Hold the wheel in place while proceeding to the next step.
    • While holding the wheel back, your chain should stop hanging.
  5. How to  Fix A Loose Bicycle Chain: 手順 5、 2の画像 1 How to  Fix A Loose Bicycle Chain: 手順 5、 2の画像 2
    • Tighten both of the loose nuts using a socket wrench, rotating the wrench from right to left, while still holding the wheel back.
  6. How to  Fix A Loose Bicycle Chain: 手順 6、 2の画像 1 How to  Fix A Loose Bicycle Chain: 手順 6、 2の画像 2
    • Check if your chain is still loose. As shown in the pictures, your chain should have more tension making it straight rather than hanging.
    • Do not place your fingers too close to the bike gear. It may accidentally spin depending on how your bike works and trap your fingers.
終わりに
After reading this guide you will never have trouble with a loose chain again.
2 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Carlos Ortiz
メンバー登録日: 01/30/22
181 ポイント
1ガイドが承認済み
チーム
CSU Los Angeles, Team 4-17, Briggs Spring 2022 CSU Los Angeles, Team 4-17, Briggs Spring 2022人のメンバー
CSULA-BRIGGS-S22S4G17
1 メンバー
2のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 14
過去 7 日: 69
過去 30 日: 378
今までの合計 25,914
