はじめに
A hole in a knit garment can easily be closed with a needle and thread. All you need is some thread in a matching color so that the repair will be as inconspicuous as possible when you’re finished.
必要な工具と部品
Turn the sweater inside out. Insert the needle through the garment at your starting point at the top of the hole. Pull the thread through until only about 5 cm of thread is overlapping. Before inserting the thread on the other side of the hole, pick up any open stitches so that no other stitches come loose.
Done! You made it.
Done! You made it.
ある他の人がこのガイドを完成しました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
これらの翻訳者の方々は世界を修理する私たちのサポートをしてくれています。 あなたも貢献してみませんか?
翻訳を始める ›
