メインコンテンツにスキップ
How do I replace the wheels on my Tobago trolley?
必要な工具と部品
  1. How do I replace the wheels on my Tobago trolley?, Wheels: 手順 1、 3の画像 1 How do I replace the wheels on my Tobago trolley?, Wheels: 手順 1、 3の画像 2 How do I replace the wheels on my Tobago trolley?, Wheels: 手順 1、 3の画像 3
    • Open the trolley and unzip the lining.
  2. How do I replace the wheels on my Tobago trolley?: 手順 2、 2の画像 1 How do I replace the wheels on my Tobago trolley?: 手順 2、 2の画像 2
    • Unscrew the 4 marked screws with a Phillips screwdriver.
    • When attaching the new wheels, take care not to over tighten the screws.
    • Use the flat-blade screwdriver to remove the 2 washers.
    • Removing the wheelhouse from the trolley.
    • Pinch off the two remaining rivets with the tongs.
  3. How do I replace the wheels on my Tobago trolley?: 手順 6、 3の画像 1 How do I replace the wheels on my Tobago trolley?: 手順 6、 3の画像 2 How do I replace the wheels on my Tobago trolley?: 手順 6、 3の画像 3
    • Remove the other 2 rivets on the outside of the trolley using the flat-blade screwdriver. Then remove the wheelhouse from the trolley.
    • When attaching the new wheelhouse, take care not to over tighten the screws.
終わりに
Follow the instructions in reverse order to finish the repair.
作成者
3人の作成者と共同で作成されました。
VAUDE Reparaturteam
メンバー登録日: 02/22/16
6,279 ポイント
32のガイドは作成済み
チーム
Vaudesport Vaudesport人のメンバー
Community
3 メンバー
96のガイドは作成済み
3 件のコメント
Dear Vaude, I have a Module 60 where the airline has managed to snap of a wheel recently. I am in contact with the UK supplier of Vaude parts, but is the repair similar to above and therefore I need to order the right hand side plastic/wheel? Thank you for any help.
JANE D - 返信
Dear Jane, yes, you can use this repair guide also for your Module Trolley. You will get a set of wheels, you so can change both if you want.
VAUDE Reparaturteam -
Dear Vaude
I have a trolley Samoa, and it seems I can't get replacements like for the Tobago. Any idea how I could find wheels to replace the broken ones?
Rollo Launche - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 22
過去 30 日: 70
今までの合計 4,921
