• After a considerable period of time, MIUI developers released Xiaomi pc suite 3.0 beta version in order to make the tool compatible with Android 6.0 marshmallow devices. But this is still in beta version and seems some features do not process successfully.
    コメントを追加する
    • Need to download into a Windows PC. Windows 7,8,8.1, Windows 10 compatible with this tool. Many smart phones from mi model, Redmimodel and also Redmi note mobile smart phones which running above instructions of Android 5 now compatible with this beta version. It included a new faster installation method but it only supports MIUI 9 ROM.
    コメントを追加する
    • Download mi pc suite 3.0 beta version into your pc and rename it to prevent from some possible errors. Run the exe file as the administrator.
    • After successful installation, the tool itself will launch. Now sign into mi account. Enable USB debugging mode of your mobile.
    • Connect your mobile to the PC. you will see a window for authorization. Click on OK in order to recognize your mobile. After successful recognition, you will see your phone specs display on the Mi pc suite.
    コメントを追加する
  1. Fixmasのスピリットを広めましょう
    クーポンコードFIXMAS12を使えば、50ドル以上のお買い上げで12ドル割引となります。
    Fixmasのスピリットを広めましょう
    • This tool can be used to flash the recovery ROM through recovery mode. This method can be used to fix the boot loop issue or to update to latest ROM version.
    コメントを追加する
    • Select the fourth option available on top of the menu bar.
    コメントを追加する
    • Boot your phone into recovery mode. Before that disconnect your mobile from the pc. Note: how to boot into recovery mode press volume up and power button altogether alternatively navigate to settings> my device> system update> click three dots on top right corner> reboot mobile to recovery mode.
    コメントを追加する
    • Step 3: Press volume down button. select "connect mi assistant" by using power button. Step 4: Phone will show an image of the phone with a USB plug in Step 5: Now reconnect your mobile to the PC and the tool to recognize your mobile.
    • Step 6: Download a suitable ROM file or else you can download a one from the tool. Step 7: Now you will redirect to another option where to chose to 'save data or not to save'. Suggest you to backup all your important data.
    • Step 8: Now choose the ROM either you have downloaded or selected from mi pc suite. Wait few minutes until verification is done by the tool and it will start the installation process. Wait a few minutes until your mobile boots up. But you have to follow this method at your own risk.
    コメントを追加する
まとめ
ある他の人がこのガイドを完成しました。
Joy merryman
メンバー登録日: 2018年11月01日
181 ポイント
4のガイドは作成済み
コメントを追加する
統計データを表示:
過去 24時間: 0
過去 7 日: 12
過去 30 日: 32
今までの合計 31
