メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
はじめに
Can iPhone 11 Pro possibly be turned into iPhone 11 Pro Max? It is actually theoretically possible. With pins of the two phones’ display connector and touch connector functioning almost the same, we can turn an iPhone 11 Pro into an iPhone 11 Pro Max by changing board ID resistors.
ビデオの概要
  1. iPhone 11 Pro VS iPhone 11 Pro Max
    • iPhone 11 Pro VS iPhone 11 Pro Max
    • iPhone 11 Pro comes with a 5.80-inch touchscreen display.
    • iPhone 11 Pro Max comes with a 6.50-inch touchscreen display.
  2. What will happen when we connect the iPhone 11 Pro Max screen with the housing of iPhone 11 Pro directly?
    • What will happen when we connect the iPhone 11 Pro Max screen with the housing of iPhone 11 Pro directly?
  3. 今あるものを使い続けましょう
    オールインワインキットで安く修理して、節約しましょう。
    iPhone 修理キットを見る
    今あるものを使い続けましょう
    iPhone 修理キットを見る
  4. Compare the motherboard of iPhone 11 Pro and that of iPhone 11 Pro Max. The component array of the two is almost the same. There is one more board ID resistor next to CPU on iPhone 11 Pro.
    • Compare the motherboard of iPhone 11 Pro and that of iPhone 11 Pro Max. The component array of the two is almost the same. There is one more board ID resistor next to CPU on iPhone 11 Pro.
    • All we need to do is remove the extra board ID resistor.
  5. We can see on the interface of 3uTools that the phone has entered DFU mode. And the phone has been turned into iPhone 11 Pro Max. We can write firmware of iPhone 11 Pro Max to the phone.
    • We can see on the interface of 3uTools that the phone has entered DFU mode. And the phone has been turned into iPhone 11 Pro Max. We can write firmware of iPhone 11 Pro Max to the phone.
Phryne
メンバー登録日: 2019年11月17日
10,251 ポイント
80のガイドは作成済み
2 件のコメント
Very impressive. Thanks a lot!
viona - 返信
hope it can help you somehow!
Phryne -
コメントを追加
統計データを表示:
過去 24時間: 5
過去 7 日: 39
過去 30 日: 167
今までの合計 1,638
