メインコンテンツにスキップ
How To Transfer Content To Your New 3DS XL
必要な工具と部品
ビデオの概要
  1. How To Transfer Content To Your New 3DS XL, How To Transfer Content To Your New 3DS XL: 手順 1、 1の画像 1
    • Start by removing the stylus from the frame of the New 3DS XL.
  2. How To Transfer Content To Your New 3DS XL: 手順 2、 3の画像 1 How To Transfer Content To Your New 3DS XL: 手順 2、 3の画像 2 How To Transfer Content To Your New 3DS XL: 手順 2、 3の画像 3
    • Loosen the two captive Phillips #1 screws on the back of the device.
    • These captive screws will conveniently stay in the rear cover, so don't try to remove them.
    • Prying from the thumb slots on each side, pull the rear panel off the back of the device.
  3. How To Transfer Content To Your New 3DS XL: 手順 3、 1の画像 1
    • Press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • Use a PC to copy the data from the source SD card to the New 3DS XL microSD card.
    • You may need a micro SD to SD adapter.
    • For reassembly, push the microSD card into the slot until it clicks in place.
終わりに
4 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Geoff Wacker
メンバー登録日: 09/30/13
91,963 ポイント
89のガイドは作成済み
2件のガイドコメント
Can anyone who's actually tried the text portion of this guide confirm whether it works? As I understand it, all the data on a 3ds is encrypted with a console-specific key (movable.sed) to prevent exactly this. If it actually worked like this, wouldn't it defeat copy protection almost entirely since any o3ds encrypted ROM could just be copied as-is to a n3ds and run normally?
darth mango - 返信
the VIDEO first and then the steps😭
WyattDYT -
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 13
過去 30 日: 70
今までの合計 7,133
