メインコンテンツにスキップ
How To Stop Sony HDR-CX240E Screen From Moving
必要な工具と部品
  1. How To Stop Sony HDR-CX240E Screen From Moving, Unscrewing The Right Panel: 手順 1、 1の画像 1
    • Unscrew the 2 Phillips #00 screws on the right side of the camera.
  2. How To Stop Sony HDR-CX240E Screen From Moving, Unscrewing the bottom: 手順 2、 1の画像 1
    • Unscrew the 4 Phillips #00 screws form the bottom of the camera.
  3. How To Stop Sony HDR-CX240E Screen From Moving, Removing The Battery Compartment Cover: 手順 3、 1の画像 1
    • Remove the battery compartment cover by pulling it while "wiggling" it. It works like a hook.
  4. How To Stop Sony HDR-CX240E Screen From Moving, Unscrewing The Left Panel: 手順 4、 2の画像 1 How To Stop Sony HDR-CX240E Screen From Moving, Unscrewing The Left Panel: 手順 4、 2の画像 2
    • Unscrew the 2 Phillips #00 screws from the left side.
    • Unscrew the Phillips #00 screw from the small SD and HDMI compartment on the left side.
  5. How To Stop Sony HDR-CX240E Screen From Moving, Removing The Small Back Panel: 手順 5、 1の画像 1
    • Using the opening tool, remove the small panel at the back of the camera.
    • Always be careful when removing any panel, so you don't break any clips.
  6. How To Stop Sony HDR-CX240E Screen From Moving, Removing The Right Panel: 手順 6、 1の画像 1
    • Carefully use the opening tool or guitar picks to remove the entire right panel from the camera.
  7. How To Stop Sony HDR-CX240E Screen From Moving, Removing The Right Lens Small Panel: 手順 7、 1の画像 1
    • Pry the tiny panel off of the left side of the lens, between the lens and the screen hinge, revealing the hinge.
  8. How To Stop Sony HDR-CX240E Screen From Moving, Removing The Lens Ring And Cover Ring: 手順 8、 1の画像 1
    • Remove the plastic lens cover, and then remove the inside black "ring" that also contains the lens protector.
  9. How To Stop Sony HDR-CX240E Screen From Moving, Removing The Last Lens Ring And Mic: 手順 9、 1の画像 1
    この手順で使用する道具:
    • Remove the last ring from around the lens, very carefully as the microphone is on it, which is connected with a ribbon cable to the camera.
    • Remove the ring carefully, since it is connected to the motherboard with a ribbon cable.
    • Then, use a pair of tweezers to carefully disconnect the ribbon cable from the board.
  10. How To Stop Sony HDR-CX240E Screen From Moving, Separating The Two Parts Of The Camera: 手順 10、 1の画像 1
    • Unscrew the Phillips #00 screw from the left side of the lens, next to the hinge.
  11. How To Stop Sony HDR-CX240E Screen From Moving, Removing The Lens: 手順 11、 1の画像 1
    • Unscrew the 3 Phillips #00 screws from around the lens of the camera.
    • Then, remove the lens using your tweezers.
    • Handle the lens with caution as it's fragile.
    • It might be a good time to clean the lens with a microfiber cloth since you've already opened the camera.
  12. How To Stop Sony HDR-CX240E Screen From Moving, Screwing The Hinge: 手順 12、 1の画像 1
    • Tilt the camera to the side of the screen.
    • Pull apart the 2 sides of the camera to make some space.
    • Don't pull the 2 sides apart with too much force!
    • Using your Phillips #00 screwdriver, carefully screw tightly the 2 screws that hold the hinge on the camera.
    • You will need to use your screwdriver "diagonally" (not straight), since having clear access to the screws would require a lot more disassembly.
終わりに
作成者
2人の作成者と共同で作成されました。
Stratos Thivaios
メンバー登録日: 02/27/23
1,305 ポイント
5のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 25
今までの合計 355
