メインコンテンツにスキップ
How To Start Remote Viewfinder on Samsung WB150F
必要な工具と部品
  1. How To Start Remote Viewfinder on Samsung WB150F, Power on the device: 手順 1、 2の画像 1 How To Start Remote Viewfinder on Samsung WB150F, Power on the device: 手順 1、 2の画像 2
    • Turn on the device by pressing the button thats labeled POWER on the top.
  2. How To Start Remote Viewfinder on Samsung WB150F, Finding Remote Viewfinder: 手順 2、 2の画像 1 How To Start Remote Viewfinder on Samsung WB150F, Finding Remote Viewfinder: 手順 2、 2の画像 2
    • Look at the wheel at the top
    • Scroll until the dot is at Wi-Fi
  3. How To Start Remote Viewfinder on Samsung WB150F: 手順 3、 3の画像 1 How To Start Remote Viewfinder on Samsung WB150F: 手順 3、 3の画像 2 How To Start Remote Viewfinder on Samsung WB150F: 手順 3、 3の画像 3
    • Navigate using the Navigation wheel
    • Navigate until the blue glowing square is on Remote Viewfinder
    • Press OK
  4. How To Start Remote Viewfinder on Samsung WB150F, Setting Up: 手順 4、 1の画像 1
    • If everything done correctly, You will be on this screen, Time to install the viewfinder app.
  5. How To Start Remote Viewfinder on Samsung WB150F, Finding the app: 手順 5、 1の画像 1
    • Search up Remote ViewFinder on App Store/Play Store
  6. How To Start Remote Viewfinder on Samsung WB150F, Downloading the app: 手順 6、 1の画像 1
    • When you found the app, Press the download button
    • If it is a cloud, It means it was installed before, You will not need a password to download it.
    • The App Is pretty outdated, I suggest using iOS 4-10, It wont work on newer iOS
    • An iPhone 5c or an iPad 4 works well.
  7. How To Start Remote Viewfinder on Samsung WB150F, Connecting: 手順 7、 2の画像 1 How To Start Remote Viewfinder on Samsung WB150F, Connecting: 手順 7、 2の画像 2
    • Open up settings and go to the Wifi Tab
    • Connect your device to the cameras wifi.
    • The Wifi name should be the same as on the camera.
  8. How To Start Remote Viewfinder on Samsung WB150F, Starting the application: 手順 8、 1の画像 1
    • Launch Remote Viewfinder on your device
  9. How To Start Remote Viewfinder on Samsung WB150F, Connecting to the camera: 手順 9、 2の画像 1 How To Start Remote Viewfinder on Samsung WB150F, Connecting to the camera: 手順 9、 2の画像 2
    • Wait until its connected.
    • If you see the screen of your camera Your camera is connected (see step 10 for controls)
  10. How To Start Remote Viewfinder on Samsung WB150F, Controls: 手順 10、 1の画像 1
    • Flash
    • Timer
    • Photo Size
    • Zoom
    • Shutter Button
    • Camera View
    • Tap the camera view to hide/show the menu.
終わりに
Close the app, to disconnect your camera from the app
作成者
1人の作成者と共同作成されました。
Artem Ivat
メンバー登録日: 02/05/20
2,631 ポイント
12のガイドは作成済み
チーム
Kid fixers Kid fixers人のメンバー
Community
149 メンバー
283のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 5
過去 7 日: 10
過去 30 日: 36
今までの合計 722
