メインコンテンツにスキップ
How To Reset a Suitcase Lock
  1. How To Reset a Suitcase Lock, How To Reset a Suitcase Lock: 手順 1、 2の画像 1 How To Reset a Suitcase Lock, How To Reset a Suitcase Lock: 手順 1、 2の画像 2
    • Set the suitcase down with the combination lock facing up.
  2. How To Reset a Suitcase Lock: 手順 2、 1の画像 1
    • Turn a flashlight towards the lock, so that you can see the small details.
  3. How To Reset a Suitcase Lock: 手順 3、 3の画像 1 How To Reset a Suitcase Lock: 手順 3、 3の画像 2 How To Reset a Suitcase Lock: 手順 3、 3の画像 3
    • Rotate the three gears together so that the grooved part of each gear faces the outside.
    • Correct: Gear faces the outside.
    • Gear faces the inside.
  4. How To Reset a Suitcase Lock: 手順 4、 1の画像 1
    • Remember the number of the three gears when the groove part is on the outside.
    • As of now the code number of the three gears is 181.
  5. How To Reset a Suitcase Lock: 手順 5、 1の画像 1
    • Add 5 to each of the three numbers. For example, my numbers are 181. After adding 5, the code to my lock would be 636.
    • Turn the numbers on the lock to 636, and then unlock the lock.
  6. How To Reset a Suitcase Lock: 手順 6、 2の画像 1 How To Reset a Suitcase Lock: 手順 6、 2の画像 2
    • Sometimes the difference is not 5 from the grooved spots. In this case, you can try to increase the numbers after adding 5.
    • For example, if 636 does not work, try to add 6 to the three numbers. Then the code is 747 and attempt to unlock the lock. Continue to add 7, then 8 to try, until it can be opened.
  7. How To Reset a Suitcase Lock: 手順 7、 2の画像 1 How To Reset a Suitcase Lock: 手順 7、 2の画像 2
    • When I added 8 and my number was 969, the lock unlocked. We successfully opened the suitcase!
終わりに
After reading my guide, you will never encounter the problem that the suitcase cannot be opened without remembering the password. It can be solved anytime, anywhere.
5 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Lisha Li
メンバー登録日: 09/17/21
445 ポイント
2のガイドは作成済み
チーム
York University, Team E-11, Melo-Thaiss Fall 2021 York University, Team E-11, Melo-Thaiss Fall 2021人のメンバー
YORK-MELO-THAISS-F21SEG11
1 メンバー
7のガイドは作成済み
4件のガイドコメント
OMG! A big THANK YOU!!! It worked.
Edward Lee - 返信
Amazing. This worked for me
Leena Daykin - 返信
It worked for me too
georgeteach - 返信
Surprised ! And grateful also to the author. I opened the lock with forgotten combination in just 3 minutes.
Chandrashekhar Dadhekar - 返信
コメントを追加
統計データ:
過去 24時間: 7
過去 7 日: 81
過去 30 日: 411
今までの合計 54,523
