メインコンテンツにスキップ
How To Replace A Subaru Outback Exhaust Front Cover
必要な工具と部品
  1. How To Replace A  Subaru Outback Exhaust Front Cover, Exhaust Front Cover: 手順 1、 1の画像 1
    • Collect Supplies.
    • Make sure the new Exhaust Front Cover is free of stickers, oil, or residues.
  2. How To Replace A  Subaru Outback Exhaust Front Cover: 手順 2、 1の画像 1
    • Park Outback on a level dry and clean surface.
    • Make sure that the car is in park for an automatic transmission or in first gear for a manual transmission. Verify that the parking brake is engaged.
  3. How To Replace A  Subaru Outback Exhaust Front Cover: 手順 3、 1の画像 1
    • Put on safety glasses. Be sure to leave them on until the fix is complete.
    • Do not touch any exhaust components until you have verified that there is no danger of getting burned.
    • Laying on your back, maneuver yourself underneath the driver or passenger side of the car carrying the 12mm combination wrench. Locate yourself about even with the back of the front door.
  4. How To Replace A  Subaru Outback Exhaust Front Cover: 手順 4、 3の画像 1 How To Replace A  Subaru Outback Exhaust Front Cover: 手順 4、 3の画像 2 How To Replace A  Subaru Outback Exhaust Front Cover: 手順 4、 3の画像 3
    • Unplug the rear oxygen sensor connector and carefully route the wires through the Exhaust Front Cover so they are no longer passing through it.
  5. How To Replace A  Subaru Outback Exhaust Front Cover: 手順 5、 3の画像 1 How To Replace A  Subaru Outback Exhaust Front Cover: 手順 5、 3の画像 2 How To Replace A  Subaru Outback Exhaust Front Cover: 手順 5、 3の画像 3
    • Locate the four mounting bolts for the Exhaust Front Cover.
    • Remove the bolts by turning them counterclockwise using the 12mm combination wrench.
  6. How To Replace A  Subaru Outback Exhaust Front Cover: 手順 6、 1の画像 1
    • Remove the old Exhaust Front Cover taking care to prevent damage to the vehicles undercoating and the oxygen sensor wires.
終わりに
To reassemble your exhaust front cover, follow these instructions in reverse order.
作成者
3人の作成者と共同で作成されました。
redacted
メンバー登録日: 02/24/15
101 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 23-1, Green Winter 2015 Cal Poly, Team 23-1, Green Winter 2015人のメンバー
CPSU-GREEN-W15S23G1
4 メンバー
4のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 14
今までの合計 1,025
