メインコンテンツにスキップ
How To Repair A Dropped External Hard Drive
必要な工具と部品
  1. How To Repair A Dropped External Hard Drive, How To Repair A Dropped External Hard Drive: 手順 1、 1の画像 1
    • Place the flathead screwdriver in between where the case and lid meet, and pry open the external case to expose the hard drive itself.
    • Once the screwdriver head is in between the opening, slide it around the case while twisting the screwdriver in order to loosen the case.
  2. How To Repair A Dropped External Hard Drive: 手順 2、 1の画像 1
    • Carefully take out the hard drive by holding the edges, and ensuring that the connector is not bent when removing from the case.
  3. How To Repair A Dropped External Hard Drive: 手順 3、 1の画像 1
    • Find the end of the foil wrap that surround the hard drive, and slowly start peeling it back until all the screws are exposed.
    • You will need to apply the foil wrap again later, so be careful when removing it.
  4. How To Repair A Dropped External Hard Drive: 手順 4、 1の画像 1
    • Begin unscrewing the screws on the lid of the hard drive using both the Phillips screwdriver, as well as the torx screwdriver where appropriate.
  5. How To Repair A Dropped External Hard Drive: 手順 5、 1の画像 1
    • Once all the screws are removed, carefully take off the lid of the hard drive, making sure you do not touch any part of the disk itself once it is exposed.
  6. How To Repair A Dropped External Hard Drive: 手順 6、 1の画像 1
    • Using the Phillips screwdriver, place it in the slot in the middle of the disk, and turn counter clockwise until the arm has been release from the disk, close to it's parked position.
  7. How To Repair A Dropped External Hard Drive: 手順 7、 1の画像 1
    この手順で使用する道具:
    購入する
    • Once the arm has been released, use a pair of tweezers to carefully ensure the arm has been placed back into it's parked position, and is off of the disk.
  8. How To Repair A Dropped External Hard Drive: 手順 8、 1の画像 1
    • Carefully place the lid back on the hard drive, making sure that you do not come in contact with the disk itself.
  9. How To Repair A Dropped External Hard Drive: 手順 9、 1の画像 1
    • Use the appropriate screwdrivers to put all the screws back in their required slots.
  10. How To Repair A Dropped External Hard Drive: 手順 10、 1の画像 1
    • Begin to place the foil back on the hard drive in the same position it was before removal, making sure that the LED on the hard drive is still visible and the foil is not blocking the connector.
  11. How To Repair A Dropped External Hard Drive: 手順 11、 1の画像 1
    • Place the hard drive back in the external case, by inserting on a 45 degree angle with the connector going in first, and then softly pushing the hard drive down until it is back in the case and it is not sticking out.
  12. How To Repair A Dropped External Hard Drive: 手順 12、 1の画像 1
    • Put the lid of the external case by pressing on both pieces until a "click" noise is heard around the case.
終わりに
作成者
2人の作成者と共同で作成されました。
Nicholas
メンバー登録日: 09/16/23
205 ポイント
1ガイドが承認済み
チーム
York University, Team 2-25, O'Regan Fall 2023 York University, Team 2-25, O'Regan Fall 2023人のメンバー
YORK-O'REGAN-F23S2G25
1 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 15
過去 7 日: 69
過去 30 日: 283
今までの合計 1,424
