はじめに
In this guide, we will be teaching you how to deconstruct a fishing rod's spin cast reel to check the finishing line to fix any blockage or snagging of the line inside of the reel.
必要な工具と部品
Find an open area in your home to lay down your fishing pole. Make sure you have space to access the reel comfortably.
Your fishing line should now be free of slack and your reel should be fully reassembled.
To test your pole, take it outside to a open area and gently cast it. It should cast in a fluid motion with no blockage in the line.
If the line smoothly releases, you have fixed the kink in your line. If your line snags, preventing the pole to cast smoothly, repeat the previous steps to find the blockage.
To reassemble the reel, simply screw the cap back onto the base and reel in any slack line.
2 の人々がこのガイドを完成させました。
コメント 1 件
Hi Kaitlyn,
It’s really a informative guide for beginners.I would like to know, which Fishing Reel you would recommend for beginners?
Thanks,
