メインコンテンツにスキップ
How To Properly Use And Maintain Your Juicer
必要な工具と部品
    • Examine whether you use a traditional centrifugal juicer or a slow auger juicer to understand performance and noise levels.
    • Recognize that smaller centrifugal models have a narrow feed chute and might require more chopping.
    • Notice that larger centrifugal models have a bigger feed chute, letting you use larger produce pieces.
    • Slow or auger juicers compress produce at lower speeds and can handle leafy greens more effectively.
    • Unplug the juicer from the power source before handling the internal parts or performing any maintenance.
    • Clean and cut fresh produce to fit into the feed chute, especially for smaller centrifugal machines.
    • Apply gentle pressure when inserting hard ingredients such as beetroot to avoid straining the motor.
    • Plug in the machine only when ready to juice and ensure the lid is securely attached.
    • For slow juicers, use the reverse function if ingredients become jammed to release stuck pieces.
    • Place a small bag inside the pulp container to make cleanup easier and allow reuse of pulp if desired.
    • Use the slow juicer to puree tomatoes or softer fruits, collecting juice and pulp separately.
    • Clean the juicer parts immediately after use to prevent build-up and reduce scrubbing time.
    • Discard or reuse all pulp, taking care to empty the container before washing.
    • Avoid using a dishwasher for the filter or mesh to prevent damage or warping.
    • Use a soft brush under running water to remove residue from both the fine mesh and removable parts.
    • Apply the same cleaning rules for slow juicers, including rinsing the auger and strainer right away.
    • Check the device manual to avoid any action that could void your warranty or risk damage.
    • Store all parts in a dry place and handle them carefully to prolong the motor and component lifespan.
終わりに
A juicer can deliver fresh, nutritious beverages if met with proper use and care. Clean right after juicing and respect the device’s specific guidelines for a smooth experience and longer service life. Always remember to unplug your juicer before any maintenance to stay safe and maintain your warranty.
作成者
1人の作成者と共同作成されました。
Ula Gantar
メンバー登録日: 01/08/25
9,730 ポイント
46のガイドは作成済み
チーム
ZEOS Slovenia ZEOS Slovenia人のメンバー
Local Repair Groups
2 メンバー
54のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 7
今までの合計 59
