メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
How To Maintain The Cooker Hood In Your Appliance
必要な工具と部品
      • Unplug the appliance from any electrical source before starting any maintenance.
      FixBotに聞いてみる
      コメントを追加
      • Detach the grease filter if it is still in place and set it aside.
      • Unscrew or unclip any external panels to expose the interior components.
      • Wear protective gloves to avoid sharp edges and greasy surfaces.
      FixBotに聞いてみる
      コメントを追加
      • Locate and remove screws or clips securing the hood interior and lamp assembly.
      • Lift away plastic or metal covers to gain access to the motor housing.
      • Detach the lamp unit gently if present to protect the bulb and wiring.
      FixBotに聞いてみる
      コメントを追加
      • Remove any electrical components or cable holders from the casing.
      • Set aside circuit boards or switches to keep them dry during cleaning.
      • Keep fasteners and small parts in a secure container for reassembly.
      FixBotに聞いてみる
      コメントを追加
      • Apply a degreasing solution liberally to all hood surfaces and let it soak for approximately 5-6 hours.
      • Use caution around broken or cracked glass components to avoid cuts.
      • Rinse or wipe away any loosened buildup after soaking.
      FixBotに聞いてみる
      コメントを追加
      • Avoid submerging the motor in water to protect windings from damage.
      • Use a suitable solvent with a cloth or brush to remove built-up grease.
      • Disassemble the motor if needed by removing its securing bolts with care.
      • Keep track of clips and photograph their positions for reference.
      FixBotに聞いてみる
      コメントを追加
      • Soak metal panels, fan covers, and removable parts in hot water or a dishwasher.
      • Inspect for sharp edges to prevent injuries during scrubbing and rinsing.
      • Dry all components thoroughly before moving on to reassembly.
      FixBotに聞いてみる
      コメントを追加
      • Lubricate bushings and the motor shaft lightly with appropriate machine oil.
      • Realign the rotor, stator, and washers, ensuring each part is in its original place.
      • Tighten bolts or nuts evenly and check for smooth rotation without friction.
      FixBotに聞いてみる
      コメントを追加
      • Repair or reinforce any cracked lamp housing with suitable materials (duck tape, double-sided tape, aluminum foil).
      • Reattach the motor and all electrical components in reverse order of removal.
      • Reinstall the grease filter and secure all casing panels firmly.
      FixBotに聞いてみる
      コメントを追加
終わりに
Maintaining your cooker hood keeps it operating at peak performance and extends its service life. Clean, lubricate, and inspect regularly to prevent excessive buildup and electrical issues. With routine care, the hood effectively removes odors and grease, promoting a safer and more pleasant cooking environment.
キャンセル: このガイドを終了できませんでした。
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Ula Gantar
メンバー登録日: 01/08/25
16,609 ポイント
81のガイドは作成済み
チーム
ZEOS Slovenia ZEOS Slovenia人のメンバー
Local Repair Groups
2 メンバー
786のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 31
過去 30 日: 155
今までの合計 1,919
