はじめに
This guide shows you how to properly use, clean, and maintain your stick blender so that it operates safely and lasts longer. It includes advice on container selection, handling hot food, avoiding damage to coated surfaces, and key precautions to help protect both you and your warranty.
手順1 Understanding short burst operation
Avoid running the motor for long periods to prevent overheating and damage.
手順2 Using the right container
Utilize various container sizes, including jars, cups, or large pots for blending.
Be gentle in coated or glass containers to avoid scraping or breakage.
手順3 Using a wrist-based mixing approach
Grip the blender firmly and pivot your wrist left and right with gentle pressure up and down.
Keep movements smooth to reduce strain on the device and produce even blending.
手順4 Handling hot contents safely
Use pulsed bursts when blending soups or sauces directly in hot pots.
手順5 Cleaning the device
Detach the blending shaft if applicable and rinse it under warm water with mild soap.
Swirl the lower end in a bowl of warm soapy water to remove stubborn debris.
手順6 Troubleshooting and sustainable tips
Allow the stick blender to cool if it stops unexpectedly or overheats before continued use.
Contact authorized service providers if the device does not function after basic checks.
Following these guidelines helps keep your stick blender in good working order. Pausing to let the motor cool ensures longer life, and using appropriate containers prevents damage. Unplugging before any service and checking warranty restrictions helps keep you safe and protects your investment.
