はじめに
It's been more than one year after launching iPhone 8 and gradually users have started to think of jailbreaking iPhone 8. Though the jailbreaking is dangerous task users always keen on it. Electra Jailbreak iOS 11.2-11.3.1 is the newly released tool to jailbreak iDevices which run iOS 11.2-11.3.1. The tool was released in July 2018 by Coolstar who is a well-known hacker and developer.
What Is Electra Jailbreak
Electra Jailbreak is one of the latest jailbreak tools which works as a semi-tethered jailbreak method. A Semi-tethered jailbreak restores your device on its original iOS, everytime you reboot it after jailbreaking. Likewise, Electra Jailbreak also restores your device every time you reboot the device after jailbreaking and you have to re-jailbreak it. Electra Jailbreak for iOS 11.2-11.3.1 has two versions.
1) Developer version that uses a multipath tcp exploit - Needs Apple developer account to use and jailbreaking valid for one year and needs re-jailbreaking after one year
2) Regular version that uses a vcf exploit - Needs Apple regular account to use and jailbreaking valid for seven days and needs re-jailbreaking after every seven days
Important Information About Latest Electra Jailbreak for iOS 11.2-11.3.1
  • Electra repo has been added and Substitute, Tweak Loader and Substrate Compatibility Layer are available
  • OpenSSH is running on port 22
  • Cydia is added which was not included in previous Electra Jailbreak version
  • RocketBootstrap 1.0.6 or higher is required for use on iOS 11
  • iDevices on iOS 11.3-11.3.1 will reboot twice and Electra will need to be re-run after the first reboot
ビデオの概要
  1. Mac or Windows computer
    • Mac or Windows computer
    • USB Cable
    • Suggested iDevice which runs iOS 11.2-11.3.1
    • Strong Internet connection
    コメントを追加する
    • In here you are guided to jailbreak your iPhone 8 using Electra Jailbreak Regular version. Therefore you do not need an Apple developer account.
    • Make a complete backup of your iDevice in iTunes or any other reliable location
    • Remove iOS 11.4 updates if you have already installed
    • Download Electra Jailbreak iOS 11.3.1 regular version and download Cydia Impactor ( Cydia Impactor depend on the computer Operating System)
    • Install both applications and launch Cydia Impactor application
    • Connect your iDevice to the computer using the USB cable and trust the computer on the iOS device
    • Drag the Electra Jailbreak IPA onto Cydia Impactor
    • Type your Apple ID and password and Click OK to sign the Electra Jailbreak IPA and upload it onto the iOS device (Signing require a strong Internet connection)
    コメントを追加する
  2. Fixmasのスピリットを広めましょう
    クーポンコードFIXMAS12を使えば、50ドル以上のお買い上げで12ドル割引となります。
    Fixmasのスピリットを広めましょう
    • Open Settings > General > Device Management and trust the certificate
    • Tap on the Electra Jailbreak profile and tap on "Trust" to verify
    • Launch the Electra iOS 11.3.1 app and tap on "Jailbreak" button
    • After Electra jailbreak, the device will respring and Cydia will be on your home screen
    コメントを追加する
    • Re-launch the Electra jailbreak app and keep trying If you cannot find the Cydia after jailbreaking with Electra jailbreak 11.3.1
    コメントを追加する
まとめ
Sally Denton
メンバー登録日: 2018年11月04日
199 ポイント
3のガイドは作成済み
コメントを追加する
統計データを表示:
過去 24時間: 2
過去 7 日: 6
過去 30 日: 34
今までの合計 53
