メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
How To Install a Mac SSD into an iFixit External Enclosure
必要な工具と部品
    1. How To Install a Mac SSD into an iFixit External Enclosure, Disassemble the enclosure: 手順 1、 3の画像 1 How To Install a Mac SSD into an iFixit External Enclosure, Disassemble the enclosure: 手順 1、 3の画像 2 How To Install a Mac SSD into an iFixit External Enclosure, Disassemble the enclosure: 手順 1、 3の画像 3
      • Slide the SSD sled out of the metal enclosure to remove it.
      FixBotに聞いてみる
      コメントを追加
    2. How To Install a Mac SSD into an iFixit External Enclosure, Install the SSD into the enclosure: 手順 2、 3の画像 1 How To Install a Mac SSD into an iFixit External Enclosure, Install the SSD into the enclosure: 手順 2、 3の画像 2 How To Install a Mac SSD into an iFixit External Enclosure, Install the SSD into the enclosure: 手順 2、 3の画像 3
      • Carefully insert your Mac OEM SSD as shown, with the golden contact pads below the connector pins facing upward.
      • The SSD and enclosure are both keyed, so the SSD can only be installed one way.
      • The SSD might take a significant amount of force to insert. Make sure you have the orientation correct before you apply any pressure.
      • When the SSD is fully inserted, the notch at the bottom of the drive should be aligned with the hole for the screw in the enclosure.
      FixBotに聞いてみる
      コメントを追加
    3. How To Install a Mac SSD into an iFixit External Enclosure: 手順 3、 1の画像 1
      • Use a Phillips driver to install the 4.5 mm screw securing the bottom of the SSD.
      FixBotに聞いてみる
      コメントを追加
    4. How To Install a Mac SSD into an iFixit External Enclosure, Reassemble the enclosure: 手順 4、 3の画像 1 How To Install a Mac SSD into an iFixit External Enclosure, Reassemble the enclosure: 手順 4、 3の画像 2 How To Install a Mac SSD into an iFixit External Enclosure, Reassemble the enclosure: 手順 4、 3の画像 3
      • Slide the SSD sled into the metal enclosure, SSD connector end first.
      • Make sure the enclosure is in the correct orientation—the sled slides in on the thin rails.
      • The USB-C port should be facing out once installed.
      FixBotに聞いてみる
      コメントを追加
    5. How To Install a Mac SSD into an iFixit External Enclosure: 手順 5、 3の画像 1 How To Install a Mac SSD into an iFixit External Enclosure: 手順 5、 3の画像 2 How To Install a Mac SSD into an iFixit External Enclosure: 手順 5、 3の画像 3
      • Place the port cover plate onto the end of the enclosure, aligning the USB-C port with its cutout.
      • The screw hole chamfers should face outwards.
      FixBotに聞いてみる
      コメントを追加
    6. How To Install a Mac SSD into an iFixit External Enclosure: 手順 6、 1の画像 1
      • Use a Phillips driver to install the two 8 mm screws onto the end of the enclosure.
      FixBotに聞いてみる
      コメントを追加
    7. How To Install a Mac SSD into an iFixit External Enclosure, Use your new external SSD: 手順 7、 1の画像 1
      • The drive is now ready to be connected to your computer with either of the included USB cables.
      FixBotに聞いてみる
      コメントを追加
終わりに
Once your drive is installed, you can transfer data from it, or use Disk Utility to format it and use it as a Time Machine backup.
キャンセル: このガイドを終了できませんでした。
12 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Carsten Frauenheim
メンバー登録日: 03/10/20
168,851 ポイント
437のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
123 メンバー
76,953のガイドは作成済み
9件のガイドコメント
Danke für das Teilen. Es wäre besser, wenn Sie ein zusätzliches Video-Tutorial haben. bloxorz
Halle Promise - 返信 共有
The problem is that unless we're talking about a 2tb or larger SSD, the enclosure for an Apple SSD costs as much or more as just buying an external SSD (as I found out the hard way).
RD6 - 返信 共有
Is there any driver that needs installed for this? My MacBook Pro, a MacBook Air, and a Windows machine do not recognize any USB storage device is being connected at all. Nothing shows up with Disk Utility.
Albert Einstein - 返信 共有
Installed an original MacBook Air 11" Early 2014 SSD drive - doesn't work at all! Waisted €119,95
Raimondas Valuckas - 返信 共有
The install was successful and the drive reads just fine. However, the drive will disconnect itself after a couple minutes. Usually while I'm transferring or browsing files to see which one to transfer next. So basically about the same as all the other generic enclosures I've bought. Is there a fix and or recourse? I don't like wasting over a c-note for something that does the same as the half-priced competitors.
DuchessLadybug - 返信 共有
コメントを追加
統計データ:
過去 24時間: 13
過去 7 日: 93
過去 30 日: 608
今までの合計 55,078
