メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
How To Install Universal LED Cab Roof Lights For A Truck
必要な工具と部品
  1. How To Install Universal LED Cab Roof Lights For A Truck, Remove the truck interior front map lamps: 手順 1、 3の画像 1 How To Install Universal LED Cab Roof Lights For A Truck, Remove the truck interior front map lamps: 手順 1、 3の画像 2 How To Install Universal LED Cab Roof Lights For A Truck, Remove the truck interior front map lamps: 手順 1、 3の画像 3
    • There are a couple ways you can power up this LED. You have the choice of adding a switch or just using the truck's interior light switch. For demonstration purposes, we are using the truck's interior lights to power up the entire assembly.
    • Expose the wires by removing the entire front map light assembly.
    FixBotに聞いてみる
    コメントを追加
  2. How To Install Universal LED Cab Roof Lights For A Truck, Do the measurement on the cab roof: 手順 2、 3の画像 1 How To Install Universal LED Cab Roof Lights For A Truck, Do the measurement on the cab roof: 手順 2、 3の画像 2 How To Install Universal LED Cab Roof Lights For A Truck, Do the measurement on the cab roof: 手順 2、 3の画像 3
    • Get up to the roof of your truck to measure where you're going to install these LED cab roof lights. You can use a dry erase marker to mark all the points where you will be drilling into the roof.
    FixBotに聞いてみる
    コメントを追加
  3. How To Install Universal LED Cab Roof Lights For A Truck, Drill holes: 手順 3、 1の画像 1
    FixBotに聞いてみる
    コメントを追加
  4. How To Install Universal LED Cab Roof Lights For A Truck, Mount the LED cab roof lamps: 手順 4、 2の画像 1 How To Install Universal LED Cab Roof Lights For A Truck, Mount the LED cab roof lamps: 手順 4、 2の画像 2
    • Use a screwdriver and attach the screws at the front and the rear of each LED roof lamp to permanently mount it.
    FixBotに聞いてみる
    コメントを追加
  5. How To Install Universal LED Cab Roof Lights For A Truck, Wiring: 手順 5、 3の画像 1 How To Install Universal LED Cab Roof Lights For A Truck, Wiring: 手順 5、 3の画像 2 How To Install Universal LED Cab Roof Lights For A Truck, Wiring: 手順 5、 3の画像 3
    • Wire up the LED lights in parallel. Use some electrical tape to secure the connections. Route the wires through the front map light assembly to complete the wiring portion.
    FixBotに聞いてみる
    コメントを追加
  6. How To Install Universal LED Cab Roof Lights For A Truck, Enjoy your new LED cab roof marker lights: 手順 6、 2の画像 1 How To Install Universal LED Cab Roof Lights For A Truck, Enjoy your new LED cab roof marker lights: 手順 6、 2の画像 2
    • Test everything and enjoy your new LED cab roof light.
    FixBotに聞いてみる
    コメントを追加
ゴール
キャンセル: このガイドを終了できませんでした。
作成者
1人の作成者と共同作成されました。
Eric Wu
メンバー登録日: 01/21/15
3,600 ポイント
23のガイドは作成済み
1件のガイドコメント
When you route the wires through the front map assembly, how exactly do you hook up the wires to the exposed map lights
Luke - 返信 共有
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 19
過去 30 日: 73
今までの合計 17,225
