メインコンテンツにスキップ
How To Install A Water Efficient Shower Head
必要な工具と部品
  1. How To Install A Water Efficient Shower Head, How To Install A Water Efficient Shower Head: 手順 1、 3の画像 1 How To Install A Water Efficient Shower Head, How To Install A Water Efficient Shower Head: 手順 1、 3の画像 2 How To Install A Water Efficient Shower Head, How To Install A Water Efficient Shower Head: 手順 1、 3の画像 3
    • First, you are going to remove the current shower head from the shower arm.
    • Twist the shower head counter clock-wise until it is completely removed from arm.
    • You will now see the existing older model ball adapter, which is not universal for modern shower heads.
  2. How To Install A Water Efficient Shower Head: 手順 2、 3の画像 1 How To Install A Water Efficient Shower Head: 手順 2、 3の画像 2 How To Install A Water Efficient Shower Head: 手順 2、 3の画像 3
    • Some showers will have a face plate connected to the wall.
    • In this case, use a chisel to gently pry the face plate from the wall.
  3. How To Install A Water Efficient Shower Head: 手順 3、 3の画像 1 How To Install A Water Efficient Shower Head: 手順 3、 3の画像 2 How To Install A Water Efficient Shower Head: 手順 3、 3の画像 3
    • Next, you will be removing the current shower arm from the wall.
    • Do this by turning the arm counter-clockwise until it releases from the wall.
    • You should use a wrench for this step.
  4. How To Install A Water Efficient Shower Head: 手順 4、 2の画像 1 How To Install A Water Efficient Shower Head: 手順 4、 2の画像 2
    • Remove the old shower arm from the wall and completely clear all debris from the hole in the wall.
    • Locate the new shower arm.
    • The shorter end will be the side you attach to the shower head.
  5. How To Install A Water Efficient Shower Head: 手順 5、 3の画像 1 How To Install A Water Efficient Shower Head: 手順 5、 3の画像 2 How To Install A Water Efficient Shower Head: 手順 5、 3の画像 3
    • Next, you are going to install the new shower arm, which is threaded on both sides to fit modern universal shower heads.
    • Start by turning the arm clockwise into the threaded pipe in the wall.
    • After a few turns with your hand, you will need to use a wrench to properly secure the arm into the wall.
  6. How To Install A Water Efficient Shower Head: 手順 6、 3の画像 1 How To Install A Water Efficient Shower Head: 手順 6、 3の画像 2 How To Install A Water Efficient Shower Head: 手順 6、 3の画像 3
    • Wrap teflon tape around the threading of the shower arm.
    • This prevents the shower head from leaking.
    • Tightly wrap teflon tape around all of the threading of the pipe.
    • Make sure you do not apply too much tape, this could make the shower head not fit correctly.
  7. How To Install A Water Efficient Shower Head: 手順 7、 2の画像 1 How To Install A Water Efficient Shower Head: 手順 7、 2の画像 2
    • If your shower has a face plate, slide the plate over the shower arm onto the wall.
  8. How To Install A Water Efficient Shower Head: 手順 8、 3の画像 1 How To Install A Water Efficient Shower Head: 手順 8、 3の画像 2 How To Install A Water Efficient Shower Head: 手順 8、 3の画像 3
    • Finally, attach the shower head by turning the threaded end clockwise tightly into the teflon wrapped end of shower arm.
    • Enjoy the savings of your new water conserving shower!
終わりに
Once finished installing the new shower head, turn on the water to make sure there are no leaks. If leaks are found, make sure all seals are tight and there is adequate teflon tape on all threading.
2 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Drew Carlson
メンバー登録日: 09/29/15
197 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 17-2, Green Fall 2015 Cal Poly, Team 17-2, Green Fall 2015人のメンバー
CPSU-GREEN-F15S17G2
4 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 19
今までの合計 1,078
