はじめに
The next time you eat an avocado or use one in a recipe, save the stone or pit. Planting your own avocado tree is fun and quite easy.
必要な工具と部品
After removing carefully the pit from the avocado wash it gently with warm water to remove all the flesh.
All avocado pits have a ‘bottom’ (from where the roots will grow), and a ‘top’ (from which the sprout will grow). The slightly pointier end is the top, and the flat end is the bottom.
Holding the pit "narrow" (pointed) side up, stick three toothpicks into the middle section at even intervals, just enough to give a firm hold. This will allow you to balance the pit on the inside of a cup, without completely inserting it into the cup.
Add water to a small, slender glass until it reaches the top rim.
The toothpicks should sit on the rim of the glass.
Place the glass with your avocado pit in a warm place with plenty of light.
Change the water every 5-7 days with fresh water.
Stay tuned to see our grown avocado tree in a few weeks! The next technique will show how to plant the avocado tree into a pot with soil.
13 の人々がこのガイドを完成させました。
