メインコンテンツにスキップ
How To Fix a Torn Book Page
必要な工具と部品
  1. How To Fix a Torn Book Page, How To Fix a Torn Book Page: 手順 1、 1の画像 1
    • Lay out all of the equipment needed for the repair.
  2. How To Fix a Torn Book Page: 手順 2、 1の画像 1
    • Place one piece of wax paper behind the torn page.
    • The wax paper is used to protect the other pages from the glue.
  3. How To Fix a Torn Book Page: 手順 3、 1の画像 1
    • Be very careful in aligning the torn piece with the page, as realignment after gluing will be difficult.
    • Make sure to align the torn pieces precisely. Placing them too closely or too far apart may create an issue in reading the pages later.
    • Align the torn pieces, so they connect the images/text accurately and neatly.
    • You may use a clamp to hold the torn pieces together to make gluing easier.
  4. How To Fix a Torn Book Page: 手順 4、 3の画像 1 How To Fix a Torn Book Page: 手順 4、 3の画像 2 How To Fix a Torn Book Page: 手順 4、 3の画像 3
    • Do not apply too much glue, only enough to evenly cover the tear between the page and the torn piece.
    • Remove any excess glue to prevent the pages from sticking to the wax paper.
    • Grab the fabric glue and squeeze a line of glue all the way along the crevice (tear).
    • Use a small paintbrush to apply a moderate amount of glue along the edges of the ripped areas.
  5. How To Fix a Torn Book Page: 手順 5、 1の画像 1
    • Place the second sheet of wax paper on top of the page you just glued.
    • Be careful when placing the wax paper on top of the wet glue. Moving the wax paper around will make the glue smear.
  6. How To Fix a Torn Book Page: 手順 6、 1の画像 1
    • Wrap the closed book with several rubber bands to squeeze and compress during drying time.
  7. How To Fix a Torn Book Page: 手順 7、 2の画像 1 How To Fix a Torn Book Page: 手順 7、 2の画像 2
    • You can also use several books or other heavy items to add extra weight.
  8. How To Fix a Torn Book Page: 手順 8、 2の画像 1 How To Fix a Torn Book Page: 手順 8、 2の画像 2
    • Let the glue dry for 6 hours minimum to ensure that it dries completely.
    • Carefully peel the top sheet of wax paper first, and then remove the bottom one afterwards.
ゴール
3 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Isa Camacho
メンバー登録日: 09/16/19
190 ポイント
1ガイドが承認済み
チーム
コメント 1 件
Thanks for article!
Alex White - 返信
コメントを追加
統計データ:
過去 24時間: 13
過去 7 日: 73
過去 30 日: 329
今までの合計 9,618
