メインコンテンツにスキップ
How To Fix a Hole in the Sole of a Shoe
必要な工具と部品
  1. How To Fix a Hole in the Sole of a Shoe, How To Fix a Hole in the Sole of a Shoe: 手順 1、 1の画像 1
    • To begin, clean the Adidas Gazelles with some water on a towel.
    • Be careful not to use too much water or you could further damage your shoes.
  2. How To Fix a Hole in the Sole of a Shoe: 手順 2、 2の画像 1 How To Fix a Hole in the Sole of a Shoe: 手順 2、 2の画像 2
    • Carefully use the utility knife to free the hole of any excess material.
    • Make sure and clear the Gazelles of any debris that that could be stuck under the loose squares of the sole.
  3. How To Fix a Hole in the Sole of a Shoe: 手順 3、 1の画像 1
    • Use 100 grit sandpaper to roughen the inside surface of the hole.
    • This will help the shoe goo grip the surface of the shoe, and produce a more lasting fix.
  4. How To Fix a Hole in the Sole of a Shoe: 手順 4、 2の画像 1 How To Fix a Hole in the Sole of a Shoe: 手順 4、 2の画像 2
    • Apply shoe goo to the inside of the hole in the sole of your Adidas Gazelles.
    • Make sure to apply evenly to avoid making your Gazelles off balance.
    • If there is anywhere else on your Gazelle's sole that could use additional protection, apply shoe goo to those surfaces as well.
  5. How To Fix a Hole in the Sole of a Shoe: 手順 5、 1の画像 1
    • Take your putty knife and smooth the shoe goo flush to the surface of the sole.
    • Try to spread the shoe goo in one direction to increase surface smoothness.
  6. How To Fix a Hole in the Sole of a Shoe: 手順 6、 1の画像 1
    • Now place your Gazelles in a safe and clean place to dry for 24 hours.
  7. How To Fix a Hole in the Sole of a Shoe: 手順 7、 1の画像 1
    • After 24 hours, use 150 grit sandpaper to rub down the surface of your filled hole to create a smooth surface.
終わりに
Now with the hole repaired your Gazelles are ready for action. With the proper care you can extend their life for many years to come.
10 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Hayden
メンバー登録日: 04/09/15
497 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 28-3, Green Spring 2015 Cal Poly, Team 28-3, Green Spring 2015人のメンバー
CPSU-GREEN-S15S28G3
4 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 11
過去 7 日: 50
過去 30 日: 190
今までの合計 21,190
