メインコンテンツにスキップ
How To Fix Stick Drift on Xbox Series X Wireless Controller (Without Opening)
必要な工具と部品
  1. How To Fix Stick Drift on Xbox Series X Wireless Controller (Without Opening), Preparing The Controller: 手順 1、 1の画像 1
    • Remove the battery case from the back of the controller
    • Remove all batteries
    • If you have a USB connected, remove it from the controller's USB port.
  2. How To Fix Stick Drift on Xbox Series X Wireless Controller (Without Opening), Preparing The Cotton Balls: 手順 2、 3の画像 1 How To Fix Stick Drift on Xbox Series X Wireless Controller (Without Opening), Preparing The Cotton Balls: 手順 2、 3の画像 2 How To Fix Stick Drift on Xbox Series X Wireless Controller (Without Opening), Preparing The Cotton Balls: 手順 2、 3の画像 3
    • Apply a moderate amount of 70% Isopropyl Alcohol to the tip of a cotton ball
    • Keep your bottle of 70% Isopropyl Alcohol away from children and avoid touching your face and open wounds while using it.
  3. How To Fix Stick Drift on Xbox Series X Wireless Controller (Without Opening), Cleaning The Thumbsticks: 手順 3、 2の画像 1 How To Fix Stick Drift on Xbox Series X Wireless Controller (Without Opening), Cleaning The Thumbsticks: 手順 3、 2の画像 2
    • Thoroughly rub the cotton ball along the inside edges of the thumbstick to clean any internal debris.
  4. How To Fix Stick Drift on Xbox Series X Wireless Controller (Without Opening): 手順 4、 1の画像 1
    • Allow the controller 1-2 minutes to dry.
  5. How To Fix Stick Drift on Xbox Series X Wireless Controller (Without Opening): 手順 5、 3の画像 1 How To Fix Stick Drift on Xbox Series X Wireless Controller (Without Opening): 手順 5、 3の画像 2 How To Fix Stick Drift on Xbox Series X Wireless Controller (Without Opening): 手順 5、 3の画像 3
    • Repeat steps 2-4 three times
  6. How To Fix Stick Drift on Xbox Series X Wireless Controller (Without Opening): 手順 6、 1の画像 1
    • Connect your wireless controller to your Xbox and test for stick drift.
    • If the problem persists, repeat step 5, or replace the potentiometers in the controller.
ゴール
9 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Russell Repair Co.
メンバー登録日: 11/26/22
2,000 ポイント
5のガイドは作成済み
9 件のコメント
I feel stupid for not attempting to clean the thumb stick with alcohol sooner. thanks for the guide!
I didn't have any isopropyl alcohol, so I had to use Dr. Bob Goldstein's Nature's Protection Herbal Bug Spray 😅
it's 98% isopropyl alcohol, 1% cedarwood oil, and 1% peppermint oil
Adam - 返信
Using Isoprop to clean contacts is effective in a lot of things. Did it work for your controller?
Russell Repair Co. -
Me sinto estúpido por não ter tentado isso ainda kkk, obrigado.
Flávio R Freitas - 返信
I’m using cotton buds instead is that okay?
daniel arnfield - 返信
@danielarnfield assuming you mean Cotton Swabs, yes, it is okay. Some people actually prefer cotton swabs because of their precision.
コメントを追加
統計データ:
過去 24時間: 98
過去 7 日: 706
過去 30 日: 3,348
今までの合計 41,743
