メインコンテンツにスキップ
How To Fix A Skipping LP Record
必要な工具と部品
  1. How To Fix A Skipping LP Record, How To Fix A Skipping LP Record: 手順 1、 1の画像 1
    • Identify the problem area by playing the LP record on a turntable.
    • Note the damaged area.
  2. How To Fix A Skipping LP Record: 手順 2、 2の画像 1 How To Fix A Skipping LP Record: 手順 2、 2の画像 2
    • Lightly sand the problem area with the sand paper in a circular motion.
    • Sand lightly as possible to not permanently damage the LP.
  3. How To Fix A Skipping LP Record: 手順 3、 2の画像 1 How To Fix A Skipping LP Record: 手順 3、 2の画像 2
    • Brush off the record with a lint-free cloth or record-cleaning brush in a circular brushing motion.
    • Move the record around using the edge of the record and the palms of your hands (as to not touch the grooves).
  4. How To Fix A Skipping LP Record: 手順 4、 3の画像 1 How To Fix A Skipping LP Record: 手順 4、 3の画像 2 How To Fix A Skipping LP Record: 手順 4、 3の画像 3
    • Put about ¼ tsp. (1.25ml) of soap in the sink.
    • Fill the sink with about 3-4 inches of lukewarm water.
    • Make sure the sink is stopped so water will not drain. To active the soap, stir it around with your hand while filling up the sink.
  5. How To Fix A Skipping LP Record: 手順 5、 2の画像 1 How To Fix A Skipping LP Record: 手順 5、 2の画像 2
    • Gloves can be worn, but are not required
    • Put the record in the sink, submerging the record.
    • Turn the record over to ensure both sides of the record were submerged in the water.
  6. How To Fix A Skipping LP Record: 手順 6、 2の画像 1 How To Fix A Skipping LP Record: 手順 6、 2の画像 2
    • Make sure the whole surface of the record is wet.
    • Wet the lint free cloth and wash the LP
    • 10 to 15 times in the circular motion seems to work well.
  7. How To Fix A Skipping LP Record: 手順 7、 2の画像 1 How To Fix A Skipping LP Record: 手順 7、 2の画像 2
    • Allow the soapy water to drain from the sink.
    • Put the LP record in the sink and run cold water over the LP record.
    • Turn the record with the palms of your hand. After one side is clean, flip it over and do the other.
  8. How To Fix A Skipping LP Record: 手順 8、 2の画像 1 How To Fix A Skipping LP Record: 手順 8、 2の画像 2
    • Take a dry lint-free cloth and dry the LP record in a circular motion until wet spots are visibly gone.
  9. How To Fix A Skipping LP Record: 手順 9、 1の画像 1
    • Set the record on the drying rack vertically.
    • Make sure the record is completely dry before playing it again. The record will become damaged, if played while the record is still damp.
終わりに
After the LP Record is completely dry, you will be able to play and enjoy the repaired record.
If the LP record is not fixed, this could indict a deep scratch that will need to be repaired by a professional.
2 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Robert Alexander
メンバー登録日: 09/29/15
173 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 10-7, Green Fall 2015 Cal Poly, Team 10-7, Green Fall 2015人のメンバー
CPSU-GREEN-F15S10G7
3 メンバー
3のガイドは作成済み
2件のガイドコメント
This is the worst advice I’ve ever read.
kalamazoometaldetecting - 返信
Did the method work though?!
DJ on Google -
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 34
今までの合計 15,907
