メインコンテンツにスキップ
How To Fix A Paper Towel Dispenser
必要な工具と部品
  1. How To Fix A Paper Towel Dispenser, How To Fix A Paper Towel Dispenser: 手順 1、 2の画像 1 How To Fix A Paper Towel Dispenser, How To Fix A Paper Towel Dispenser: 手順 1、 2の画像 2
    • Open the paper-towel dispenser's cover using your Philips head screwdriver and turn it counter-clockwise.
    • Some paper-towel dispensers require a key to unlock them. The lock is generally located on the top of the paper-towel dispenser.
  2. How To Fix A Paper Towel Dispenser: 手順 2、 1の画像 1
    • Look for jams. Check every space inside the paper-towel dispenser for wads of paper towels. Remove any stray bits of paper towel that you find.
  3. How To Fix A Paper Towel Dispenser: 手順 3、 1の画像 1
    • Tear off the paper towels just above the rollers.
    • Remove the roll of paper towels. Pull the lever of the paper-towel dispenser a few times to dislodge any remaining paper towels.
  4. How To Fix A Paper Towel Dispenser: 手順 4、 3の画像 1 How To Fix A Paper Towel Dispenser: 手順 4、 3の画像 2 How To Fix A Paper Towel Dispenser: 手順 4、 3の画像 3
    • Replace the roll of paper towels. Make sure the roll is coming over the top towards you. Sometimes the paper towels will still come out of the dispenser if the roll is backward, but will tear off inside the dispenser and cause jams.
    • Push holsters outwards when attempting to put a new roll in.
  5. How To Fix A Paper Towel Dispenser: 手順 5、 3の画像 1 How To Fix A Paper Towel Dispenser: 手順 5、 3の画像 2 How To Fix A Paper Towel Dispenser: 手順 5、 3の画像 3
    • Feed the paper towels through the rollers. Pull the paper-towel dispenser's lever three or four times to make sure the paper is completely fed through.
    • Don't get your fingers caught!
  6. How To Fix A Paper Towel Dispenser: 手順 6、 1の画像 1
    • Close the paper-towel dispenser's cover. Turn tool clockwise to lock. If there is a key, lock the paper-towel dispenser.
終わりに
To repair your device, follow these instructions in order.
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Jeevan Vase
メンバー登録日: 02/24/15
138 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 24-5, Green Winter 2015 Cal Poly, Team 24-5, Green Winter 2015人のメンバー
CPSU-GREEN-W15S24G5
3 メンバー
4のガイドは作成済み
4 件のコメント
What to do if the screw on the top rotates freely and does not open the dispenser? How to open the dispenser then?
sheinsalu - 返信
same problem!!! how do you open it if just keep turning?
Nena Keller - 返信
Use a flat head and go deeper
Deborah Sharkey - 返信
What if your dispenser is old ? Can the springs be replaced?
Julie Newton - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 61
過去 30 日: 230
今までの合計 56,776
