メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
How To Fix A Leaky Faucet
必要な工具と部品
  1. How To Fix A Leaky Faucet, Cartridge Faucet: 手順 1、 2の画像 1 How To Fix A Leaky Faucet, Cartridge Faucet: 手順 1、 2の画像 2
    • Shut off the hot and cold water valves underneath the sink by twisting them clockwise until they are tight.
    • The appearance of these valves will differ from sink to sink, but most operate the same.
    • To test that the water has been completely shut off, try turning on the faucet like you would normally. If no water comes out, you're in luck!
    • When reopening the valves after the repair, leave the faucet in its on position. This will prevent pressurized air from building up in the faucet cartridge.
    FixBotに聞いてみる
  2. How To Fix A Leaky Faucet: 手順 2、 3の画像 1 How To Fix A Leaky Faucet: 手順 2、 3の画像 2 How To Fix A Leaky Faucet: 手順 2、 3の画像 3
    • Pull up on the the pop-up drain stopper to seal the sink drain.
    • Place a towel in the sink to catch any excess water or faucet hardware.
    FixBotに聞いてみる
  3. How To Fix A Leaky Faucet: 手順 3、 3の画像 1 How To Fix A Leaky Faucet: 手順 3、 3の画像 2 How To Fix A Leaky Faucet: 手順 3、 3の画像 3
    • Use your fingers or a prying tool to remove the plug button from the top of the faucet handle.
    FixBotに聞いてみる
  4. How To Fix A Leaky Faucet: 手順 4、 1の画像 1
    • Use a screwdriver to remove the single handle screw.
    • The number and head type/length of the screws may vary from faucet to faucet.
    FixBotに聞いてみる
  5. How To Fix A Leaky Faucet: 手順 5、 3の画像 1 How To Fix A Leaky Faucet: 手順 5、 3の画像 2 How To Fix A Leaky Faucet: 手順 5、 3の画像 3
    • Gently pull the faucet handle up from the rest of the faucet.
    FixBotに聞いてみる
  6. How To Fix A Leaky Faucet: 手順 6、 2の画像 1 How To Fix A Leaky Faucet: 手順 6、 2の画像 2
    • Remove the temperature limit stop from the top of the cartridge.
    • When removing the temperature limit stop and indexer, take note of their position. The limit stop and indexer determine the maximum temperature that water can reach when coming out of the faucet.
    • Even if you mark the position of the indexer and stop, you may still need to reset the temperature limit after addressing the leak. Follow the instructions for your specific faucet if they are available.
    FixBotに聞いてみる
  7. How To Fix A Leaky Faucet: 手順 7、 3の画像 1 How To Fix A Leaky Faucet: 手順 7、 3の画像 2 How To Fix A Leaky Faucet: 手順 7、 3の画像 3
    • Unscrew the bonnet from the faucet.
    FixBotに聞いてみる
  8. How To Fix A Leaky Faucet: 手順 8、 2の画像 1 How To Fix A Leaky Faucet: 手順 8、 2の画像 2
    • Remove the temperature limit indexer from the top of the cartridge.
    FixBotに聞いてみる
  9. How To Fix A Leaky Faucet: 手順 9、 2の画像 1 How To Fix A Leaky Faucet: 手順 9、 2の画像 2
    • Use an adjustable wrench to loosen the bonnet nut.
    FixBotに聞いてみる
  10. How To Fix A Leaky Faucet: 手順 10、 2の画像 1 How To Fix A Leaky Faucet: 手順 10、 2の画像 2
    • Remove the bonnet nut.
    FixBotに聞いてみる
  11. How To Fix A Leaky Faucet: 手順 11、 2の画像 1 How To Fix A Leaky Faucet: 手順 11、 2の画像 2
    • Remove the cartridge.
    FixBotに聞いてみる
  12. How To Fix A Leaky Faucet: 手順 12、 3の画像 1 How To Fix A Leaky Faucet: 手順 12、 3の画像 2 How To Fix A Leaky Faucet: 手順 12、 3の画像 3
    • Remove the cartridge o-rings.
    • If the leak has been coming only from the end of the faucet, replace the cartridge.
    • If the faucet has been leaking from the base or from the faucet handle, replace the o-rings.
    • When installing new o-rings, be sure to properly seat them into the grooves on the underside of the cartridge. A misaligned o-ring can easily cause a new leak.
    FixBotに聞いてみる
  13. How To Fix A Leaky Faucet: 手順 13、 2の画像 1 How To Fix A Leaky Faucet: 手順 13、 2の画像 2
    • When reinserting the cartridge, be sure that the keys on the cartridge line up with the keys on the base of the faucet.
    FixBotに聞いてみる
終わりに
3 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Geoff Wacker
メンバー登録日: 09/30/13
92,717 ポイント
89のガイドは作成済み
1件のガイドコメント
I am looking for the brand of the faucet in this picture. We have one faucet and need aerator for it but no brand on it...?
Kittie Finch - 返信 共有
コメントを追加
統計データ:
過去 24時間: 14
過去 7 日: 347
過去 30 日: 1,599
今までの合計 9,144
