メインコンテンツにスキップ
How To Fix A Hole In Khaki Pants
必要な工具と部品
  1. How To Fix A Hole In Khaki Pants, How To Fix A Hole In Khaki Pants: 手順 1、 1の画像 1
    • Examine the damaged area.
    • Make sure to clean all the debris from the tear.
  2. How To Fix A Hole In Khaki Pants: 手順 2、 1の画像 1
    • Flip your pants inside out.
  3. How To Fix A Hole In Khaki Pants: 手順 3、 1の画像 1
    • Pinch hole together.
    • Make sure there is no gaps showing.
  4. How To Fix A Hole In Khaki Pants: 手順 4、 1の画像 1
    • Pin needle and thread through pants.
    • Use more thread than needed so you will have enough.
    • Make sure your hand is not directly behind the needle where you are poking. This will prevent you from pricking yourself.
  5. How To Fix A Hole In Khaki Pants: 手順 5、 2の画像 1 How To Fix A Hole In Khaki Pants: 手順 5、 2の画像 2
    • Pull needle and thread through pants until there is only 2 inches of thread left.
    • Tie a knot at the end of the remaining 2 inches.
    • It can be any measurement, but 2 inches makes it easier to tie a knot without wasting too much thread.
  6. How To Fix A Hole In Khaki Pants: 手順 6、 2の画像 1 How To Fix A Hole In Khaki Pants: 手順 6、 2の画像 2
    • Take the needle and pin it through right next to the previous spot.
    • Pull all the way through until thread is tight.
    • Repeat this process until you reach the end of the hole.
  7. How To Fix A Hole In Khaki Pants: 手順 7、 1の画像 1
    • Wrap the thread three times around the needle.
    • Pull the needle until the thread is tight.
    • This will tie a knot at the end.
  8. How To Fix A Hole In Khaki Pants: 手順 8、 1の画像 1
    • Take the scissors and cut the excess string remaining.
  9. How To Fix A Hole In Khaki Pants: 手順 9、 1の画像 1
    • Now put your khaki pants on because they are now wearable again and practically new!
終わりに
Now your old ripped pants look practically new and you can begin wearing them again.
6 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Calvin Roth
メンバー登録日: 09/27/15
291 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 17-1, Green Fall 2015 Cal Poly, Team 17-1, Green Fall 2015人のメンバー
CPSU-GREEN-F15S17G1
4 メンバー
5のガイドは作成済み
5 件のコメント
it's 100% not ok...... i con do it so 99% ok
Shafikahmed - 返信
and 100% maching
Shafikahmed - 返信
Iam shafik i can't do it's and 100% maching
Shafikahmed - 返信
What about if you’re in school and your pants rip?
EMMA MILLER - 返信
is it smooth when you fix it? i use these for school and dont want it to show
JORDI ZAMUDIO - 返信
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 32
過去 30 日: 141
今までの合計 51,015
