メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
はじめに
Is your Hover-1 riding slowly, dying while riding, or not going as fast? If you are facing these problems, a simple replacement of the battery could solve your issues. You will need a Phillips #1 screwdriver to remove the screws.
パーツ
パーツは指定されていません。
  1. Orient the hoverboard so that the pads are facing down. With the Phillips #1 screwdriver, remove all 18 of the screws on the underside of the board. Carefully remove the shell, lifting directly up.
    • Orient the hoverboard so that the pads are facing down.
    • With the Phillips #1 screwdriver, remove all 18 of the screws on the underside of the board.
    • Carefully remove the shell, lifting directly up.
  2. Remove the 4 screws around the battery on the case using the Phillips #1 screwdriver. Remove the case that houses the battery. Remove the case that houses the battery.
    • Remove the 4 screws around the battery on the case using the Phillips #1 screwdriver.
    • Remove the case that houses the battery.
  3. Pinch and pull apart the connecting black and yellow cable. Remove the battery from the hoverboard. Remove the battery from the hoverboard.
    • Pinch and pull apart the connecting black and yellow cable.
    • Remove the battery from the hoverboard.
終わりに
To reassemble your device, follow the instructions in step 1 in reverse order.
Camron Clifton
メンバー登録日: 2018年10月22日
331 ポイント
3のガイドは作成済み
チーム
UC Davis, Team S7-G5, Lore Fall 2018 UC Davis, Team S7-G5, Lore Fall 2018人のメンバー
UCD-LORE-F18S7G5
3 メンバー
3のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 1
過去 7 日: 8
過去 30 日: 52
今までの合計 1,335
