メインコンテンツにスキップ
Hover-1 Titan Wheel and Motor Replacement
必要な工具と部品
  1. Hover-1 Titan Wheel and Motor Replacement, Bottom Left Panel: 手順 1、 2の画像 1 Hover-1 Titan Wheel and Motor Replacement, Bottom Left Panel: 手順 1、 2の画像 2
    • Flip the hoverboard so the bottom is facing up.
    • The left side is the side that has the charge port. There is also an "L" on the metal plate underneath the wires.
  2. Hover-1 Titan Wheel and Motor Replacement: 手順 2、 2の画像 1 Hover-1 Titan Wheel and Motor Replacement: 手順 2、 2の画像 2
    • Using a Phillips #1 screwdriver, remove the two 14 mm screws located closest to the center of the hoverboard.
    • Using a Phillips #1 screwdriver, remove the four 12 mm screws located in the middle of the panel.
    • Using a Phillips #1 screwdriver, remove two 15 mm screws located closest to the wheel.
  3. Hover-1 Titan Wheel and Motor Replacement: 手順 3、 3の画像 1 Hover-1 Titan Wheel and Motor Replacement: 手順 3、 3の画像 2 Hover-1 Titan Wheel and Motor Replacement: 手順 3、 3の画像 3
    • Grip the bottom left panel and lift up to remove.
  4. Hover-1 Titan Wheel and Motor Replacement, Wheel and Motor: 手順 4、 2の画像 1 Hover-1 Titan Wheel and Motor Replacement, Wheel and Motor: 手順 4、 2の画像 2
    • Unplug the battery by pulling apart the yellow connectors.
  5. Hover-1 Titan Wheel and Motor Replacement: 手順 5、 2の画像 1 Hover-1 Titan Wheel and Motor Replacement: 手順 5、 2の画像 2
    • Use the Phillips #1 screwdriver to remove the four 12mm screws that attach the gyroscope/motherboard to the hoverboard.
  6. Hover-1 Titan Wheel and Motor Replacement: 手順 6、 3の画像 1 Hover-1 Titan Wheel and Motor Replacement: 手順 6、 3の画像 2 Hover-1 Titan Wheel and Motor Replacement: 手順 6、 3の画像 3
    • Cut the rubber surrounding the yellow wire and pull the rubber apart, exposing the connectors.
  7. Hover-1 Titan Wheel and Motor Replacement: 手順 7、 2の画像 1 Hover-1 Titan Wheel and Motor Replacement: 手順 7、 2の画像 2
    • Unplug the yellow wires by gripping the wire close to the connectors and pulling apart.
  8. Hover-1 Titan Wheel and Motor Replacement: 手順 8、 3の画像 1 Hover-1 Titan Wheel and Motor Replacement: 手順 8、 3の画像 2 Hover-1 Titan Wheel and Motor Replacement: 手順 8、 3の画像 3
    • Cut the rubber surrounding the green wire and pull the rubber apart, exposing the connectors.
  9. Hover-1 Titan Wheel and Motor Replacement: 手順 9、 2の画像 1 Hover-1 Titan Wheel and Motor Replacement: 手順 9、 2の画像 2
    • Unplug the green wires by gripping the wire close to the connectors and pulling apart.
  10. Hover-1 Titan Wheel and Motor Replacement: 手順 10、 3の画像 1 Hover-1 Titan Wheel and Motor Replacement: 手順 10、 3の画像 2 Hover-1 Titan Wheel and Motor Replacement: 手順 10、 3の画像 3
    • Cut the rubber surrounding the blue wire and pull the rubber apart, exposing the connectors.
  11. Hover-1 Titan Wheel and Motor Replacement: 手順 11、 2の画像 1 Hover-1 Titan Wheel and Motor Replacement: 手順 11、 2の画像 2
    • Unplug the blue wires by gripping the wire close to the connectors and pulling apart.
  12. Hover-1 Titan Wheel and Motor Replacement: 手順 12、 3の画像 1 Hover-1 Titan Wheel and Motor Replacement: 手順 12、 3の画像 2 Hover-1 Titan Wheel and Motor Replacement: 手順 12、 3の画像 3
    • Unplug the rainbow connector by squeezing the clips and pulling apart.
  13. Hover-1 Titan Wheel and Motor Replacement: 手順 13、 2の画像 1 Hover-1 Titan Wheel and Motor Replacement: 手順 13、 2の画像 2
    • Use scissors to cut the zip tie around the group of wires.
  14. Hover-1 Titan Wheel and Motor Replacement: 手順 14、 3の画像 1 Hover-1 Titan Wheel and Motor Replacement: 手順 14、 3の画像 2 Hover-1 Titan Wheel and Motor Replacement: 手順 14、 3の画像 3
    • Unplug the white wire connector by squeezing the clips and pulling apart.
  15. Hover-1 Titan Wheel and Motor Replacement: 手順 15、 2の画像 1 Hover-1 Titan Wheel and Motor Replacement: 手順 15、 2の画像 2
    • Use an impact driver with a hex 6 bit to loosen the four 20 mm hex 6 bolts.
    • Wear safety glasses while using the impact driver.
  16. Hover-1 Titan Wheel and Motor Replacement: 手順 16、 3の画像 1 Hover-1 Titan Wheel and Motor Replacement: 手順 16、 3の画像 2 Hover-1 Titan Wheel and Motor Replacement: 手順 16、 3の画像 3
    • Pull out the loosened screws with your hands and remove the metal plate.
  17. Hover-1 Titan Wheel and Motor Replacement: 手順 17、 2の画像 1 Hover-1 Titan Wheel and Motor Replacement: 手順 17、 2の画像 2
    • Lift the wheel and motor shaft up and out of the board.
    • The motor shaft is located within the wheel.
終わりに
3 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Emma Huun
メンバー登録日: 10/08/18
312 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team S15-G4, White Fall 2018 Cal Poly, Team S15-G4, White Fall 2018人のメンバー
CPSU-WHITE-F18S15G4
4 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 24
過去 30 日: 50
今までの合計 1,683
